Northstar motor install
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, Northstar motor install in Cadillac Engine Discussion; Hi, I have a 98 deville I had to replace the motor that part was easy here's the problem, I ...
    dwalker42 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    5
    Hi,
    I have a 98 deville I had to replace the motor that part was easy here's the problem, I can get my car to turn over but it will not stay cranked. The anti theft system shuts the car done. How do I reset this anti theft system? Its weird because if I spray ether on the carborator the engine will start but as soon as I stop spraying the ether the car shuts off. So is there something not talking to the other.
    Help!Help!Help!
    dwalker42
    69
    82,268
    Re: Northstar motor install
    Start by pulling the DTC's. The anti theft system is shutting down the injectors. There is no carburetor. It is a throttle body (TB).
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,826
    Excessive use of starting fluid (ether spray) will wash the lubrication off the cylinder walls and valve guides. Be careful.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Check the fuel pressure. You might have a problem there. It could be wiring or the pump may have failed.
    Sep 2007
    5
    Thanks bunches! what are the DTC's? where do I find these and what do I do after I have pulled the DTC's dwalker42
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Quote Originally Posted by dwalker42 View Post
    you really need to use search and read the sticky.
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    Sep 2007
    5
    Thanks got my answer DTC's are the diagnostic trouble codes! Thanks so much!
    Sep 2007
    5
    Ranger, can you tell me how to reset my DTC's for the anti theft system?
    69
    82,268
    The "sticky" in the Tech Tips section will tell you how to clear them.
    Sep 2007
    5
    Can anyone help me? The following codes come up when I pulled my DCT's but I do not quite understand how to reset them. I have the following codes
    PZM U1255, PZMB2719, IPCB2750, IPCU1255, TCSU1255, TCSC1276, ACMU1255, RFAU1255, MMMU1016
    It appears there is a loss of communication. Is this because I changed the motor, why does the car turn over but will not stay running?
    Help!
    Sep 2003
    Arizona
    3,531
    You can clear codes by discoing the battery or from the dash (on a caddy) but if they immediately return it means the problem is still there. You cannot "turn them off" if there is a problem.
    Did you check fuel pressure??????????????????????
    Starting with spray, but not running, usually indicates no fuel pressure or no injector pulse. Please check that. There is a Schrader valve on the fuel line at the intake, check there.
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction)
    B2719 - CTD-Trunk Tamper Switch Fault
    B2750 - PASSKey Data Communication Failure
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) Instrument Panel Computer
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) Traction Control System Computer
    C1276 - Delivered Torque Signal Circuit Malfunction
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) ACM
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) RFA
    U1016 - Loss of Communications with PCM
    Are you using the original PCM that came in the car, or did you change it to one that came with the engine? What other changes have you made? New key perhaps?
  15. Remove Advertisements
