crankshaft postion sensor
Results 1 to 13 of 13
Northstar Engines and System Technical Discussion Discussion, crankshaft postion sensor in Cadillac Engine Discussion; Hello i own 1997 deville i have a p0300 code i put on scanner 1.3.5.7 cylinders misfiring put spark tester ...
    mikeylok13 is offline Cadillac Owners Member
    Jun 2006
    10
    i have a p0300 code i put on scanner 1.3.5.7 cylinders misfiring put spark tester in between coil and wires very erratic spark 1,3,5,7 can crankshaft postion sensor be the cause of misfire?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: crankshaft postion sensor
    I believe your vehicle has the earlier 4-coil waste spark ignition system. Basically, the system fires TWO spark plugs at the same time: the "Power" spark, at near TDC of the compression cylinder, and, simultaneously, the "Waste" cylinder which is at (near) the top of the exhaust stroke. If you have weak spark on 1,3,5,7, then something is wrong with the 4 cylinder(s) spark on the ("front??") of the engine, but it isn't related to ignition timing, because those cylinders don't fire in that order. You need a pre-'98 technician. Someone versed in waste spark systems should be able to diagnose your problem quickly. It's probably a simple repair. Good luck! You may need something as simple as new spark plug wires........or, if the coils prove weak, a new coil pack.
    68
    81,917
    I would venture a guess that the common denominator is the ICM. Make sure all 4 connectors are clean & tight.
    Jun 2006
    10
    thank you for your info icm is what the service manual says i got a icm coil pack from junk yard didnt help ran the same i will look into waste spark system
    68
    81,917
    Waste spark is not a system. It is just the way the ignition system operates.
    Jun 2006
    10
    changed the icm runs better but still has a miss i noticed if i turn on a/c the car idles fine but in park has misfire
    68
    81,917
    Sounds a lot like my '97 Deville right after the fuel rail recall. Ended up being the wires. Do a search for "Stutter, Engine or Trans?"
    Jun 2006
    10
    well today i got my wires from rockauto but it did not help the miss
    cadillac8686's Avatar
    cadillac8686 is offline Cadillac Owners Member
    Automobile(s): Pearl White 2002 Cadillac STS
    Oct 2007
    Ohio
    33
    54
    What can a bad crank sensor do? Does it rob from performance, drivability? I know mine is bad because I had my brother put the car on the computer and I have some codes which one of them he said was the crank sensor! how much is a thing like this and what does it take to get it fixed? Any help would be great I just want no problems with my 02 STS
    68
    81,917
    It will cause intermittent stalls. I think they are about $50 each or so from http://www.rockauto.com. They are above the oil filter adapter, which must be removed to access them (it's still a tight fit). Dealer will charge $400 - $500 for the job.
    No need to put the car on a computer to retrieve the DTC's. Your car is self diagnostic. See the as "sticky" in the Tech Tips section.
    Oct 2007
    Ohio
    33
    54
    I know, my car stalls a bit all the time. Now I know why........ I know how to get to the codes. I clear them alot.
    Feb 2006
    55,891
    If you live in an emissions testing state or county, don't clear codes for a couple of weeks before you go for the OBD II plug-in test. An inadequate number of completed driving cycles will show up as a "System not ready" test code and the car will fail.
    Oct 2007
    Ohio
    33
    54
    Thanks.
  16. Remove Advertisements
