humming noise
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, humming noise in Cadillac Engine Discussion; I have a 96 sts and it makes a humming or buzzing or low roaring noise (hard to describe) while ...
    ebshumidors is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    1
    humming noise
    I have a 96 sts and it makes a humming or buzzing or low roaring noise (hard to describe) while driving. With the steering neutral or left turns only. In partial throttle or decel it is most noticeable. The CV joints do click during turns. It is not noticeable truning the wheel while not moving. Also no codes. Any ideas?
    68
    82,076
    Re: humming noise
    Sounds like a right front wheel bearing. Does the sound come and go as you make a series of "S" turns like a NASCAR driver warming his tires?
