crank sensors
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, crank sensors in Cadillac Engine Discussion; 96 STS. are the connectors on the wire harness for the crank sensors the same? can you reverse them and ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    crank sensors
    96 STS. are the connectors on the wire harness for the crank sensors the same? can you reverse them and have no issues? i pulled my motor and when i plugged the sensors in, 1 felt ok but the 2nd seemed tight. the car runs fine and no codes. just wondering.
    68
    81,917
    Re: crank sensors
    Seeing as there are two of them and they are designated sensor "A" & "B", I would suspect they should not be switched. As to whether or not they can, I don't know, but I would guess that they would have different connectors to prevent that.A FSM or a close inspection would tell.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: crank sensors
    Quote Originally Posted by stoveguyy View Post
    The upper connector will only go on the upper one. The lower will go on both.
