What Northstar do I have?
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Northstar Engines and System Technical Discussion Discussion, What Northstar do I have? in Cadillac Engine Discussion; I have found a complete 1996 Northstar engine. It is out of the car. How can I tell if it ...
    442JoeRed is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    14
    I have found a complete 1996 Northstar engine. It is out of the car. How can I tell if it is the 275 or 300 hp version? I do not have access to the car and VIN #. There is a bar code sticker on the back valve cover.
    Joe
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: What Northstar do I have?
    Quote Originally Posted by 442JoeRed View Post
    Joe
    look for a pad on the block just above the case joint on the back (right) side near the timing cover. The VIN will be stamped or etched in. If you see a metal tag (early production) that is the # I need to check. Yes the valve cover code will work, but the VIN is better
    Sep 2007
    14
    6tu287070
    Sep 2007
    14
    The Bar code is: T10L441407
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    URBANDALE, IA or CLIVE, IA
    on 11/02/2004 it had 106509 miles
    6KF69 -1996 DEVILLE CONCOURS 1G6KF5296TU287070
    That would be a high mile 300 hp
    Sep 2007
    14
    Thank you for all the info. It was pulled out of a rear hit totaled car about 3 years ago. Should still run. If not guess it was worth $200 for parts.
    Joe
    mscatena is offline Cadillac Owners Member
    Sep 2007
    6
    AJ I'm in the same situation pulled a motor from a junk yard for my sand rail build, looking for more info on the origin and car
    bar code T10L602646
    block left side upper case seam 12554367-1
    block right side lower case seam 3522506
    prod plate # TU613176 (the first # looked more like a symbol "oval over an L")
    your help is greatly appreciated!
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by mscatena View Post
    bar code T10L602646
    1996 275 hp VIN Y engine from a Eldo. strange option....UNIT SOLD FROM ENTERPRISE STOCK
    It was sold from Enterprise stock to PENSKE?
    Sep 2007
    6
    AJ you are awesome!
    Sep 2007
    6
    any chance of getting the actual VIN for a car fax report?
    tsi18psi is offline Cadillac Owners Member
    Sep 2007
    5
    How are you getting this info?Carfax or sumthing?
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    1G6EL12Y2TU613176 ------- FLEET/DAILY RENTAL
    This car had never been to a dealer for any type of repairs including recalls.
    Vehicle Has No Associated Claim History
    It has an open recall for the fuel rail
    LD8 - 4.6 L V8 DOHC NORTHSTAR ENGINE
    PeteAyala is offline Cadillac Owners Member
    Automobile(s): 91 Cadillac ETC, 93 Allante
    Sep 2007
    Detroit
    14
    I have the complete Northstar and trans in cradle. VIN code:1G6KD57Y06U100044. I was going to put it in a 91 ETC, but I just picked up a 93 Allante 1G6VS3394PU126587 with 127,000 miles. Now I'm considering putting the new Northstar in the Allante and the 93 Allante's engine in the 91 ETC. What is the hoursepower of these engines? Any thoughts on the transplants?
  16. #14
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by PeteAyala View Post
    1G6KD57Y06U100044
    6U100044 Just seeing the last 8 I knew that you should not have the powertrain unit!
    This VIN is for a SCRAPPED 06 DTS. It was about the 40th car to roll off the line when they redesigned the car.
    The car was supposed to be destroyed You can get someone in a little trouble. I know of one scenario that is some what ok, but The facility could still get in trouble.
    oh yeah a VIN Y is a 275 hp?
  17. #15
    Sep 2007
    Detroit
    14
    Wow! Thanks, I got the engine off of eBay from a company that only deals with GM parts. I went to their yard, which by the way is huge. I think they are an official GM vendor. Anyway, based on your information, I think I should keep the 300 HP in the Allante despite the mileage and go with my original plan to put the new engine in the 91 ETC, boosting the HP by 75 HP. However, if I can somehow boost the HP of the very low mileage engine to say 325-75 HP for a reasonable price I would want to put it in the Allante'.
    The ETC runs strong but has lifter noise on start-up and leaks and consumes oil, possible rear main seal and blown head gasket.
    When I worked at Cadillac headquaters in the early 90s I saw and rode in Eldorados that the Northstars where tested in. This cradle of this Y engine seams different from the one in the 91 ETC. I know the engine mount was updated but the cradle looks longer. My plan was to drop the old one and bolt up the Y, swap out the ECM and get a harnes extention. My concern about the cradle and desire to put a team together so I can video the project and put it on my website: http://www.beastkillercars.com, has kept me from moving ahead. In the meantime, I found the Allante. What do you think?
    I will up-load new photos latter today
  18. Remove Advertisements
