02 deville spark plug replacement
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, 02 deville spark plug replacement in Cadillac Engine Discussion; Tried searching through the site for this and couldn't find it. Is there a thread out there that gives instructions ...
    townclown is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    9
    Tried searching through the site for this and couldn't find it. Is there a thread out there that gives instructions on changing out plugs in an 02 deville? I popped the cover off the front bank today and could see them sitting down in the rubber tubes, but didn't want to do any damage so thought better of going any farther. Do those rubber tubes come out, do I have to pull the valve cover to get at them? Any tricks to this?
    68
    81,883
    Re: 02 deville spark plug replacement
    Cam cover stays in place. The boots come out. You were almost there.
    Jun 2007
    9
    So I just yank the boot with a pair of pliers and that's it? No danger of ripping those boots apart or anything? Give them a twist or something as I yank them?
    68
    81,883
    I have yet to have to do plugs on a COP ignition, but I would treat them just like a spark plug wire boot and give them a twist.
    Jun 2007
    9
    I'll let you know next weekend what happened...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    49
    6,919
    I don't know if it's necessary or not but the service manual says to use a spark plug boot puller to get those off.
    Jun 2007
    9
    Hmm, they're kind of hollow mushroomed shaped... I'm not sure I have the clearance to get the boot puller by the top and down onto the stem. I'll give that the first shot tho.
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Maybe it's a special one? I don't know.
    Quote Originally Posted by townclown View Post
  11. Remove Advertisements
