How to get out cylinder head alignment bushings???
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, How to get out cylinder head alignment bushings??? in Cadillac Engine Discussion; cylinder head alignment bushings: These bushings don`t want to come out, how do you pulled this?...
    irebroff's Avatar
    irebroff is offline Cadillac Owners Member
    Automobile(s): Seville STS 1999
    Nov 2005
    Germany - Bavarian
    86
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: How to get out cylinder head alignment bushings???
    You will destroy them to remove them. I cut a groove down to the block, then crushed what was left. With a dremel you can cut a little deeper.
    People have threaded things into them. I don't think anyone has saved them.
    irebroff's Avatar
    Nov 2005
    Germany - Bavarian
    86
    ...and then you used new one? Or nothing?
    racerxnet is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    9
    Insert a bolt into the dowel about the same size and crush the dowel with a pair of vise grips. It will crush against the bolt leaving it usable after removal. You will need to touch up the gouges with a file or grinder.
    MAK
    Sep 2003
    Arizona
    3,531
    You need new ones.
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    I am not at that skill level yet. Tomorrow I hope to learn how to put air in tires.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    I use a Snapon tool. # REX116A. Screw Extractor. I install it part way and then place Vise Grips around it. After that you can turn it out. 1/2 drill size
    97Concours1 is offline Cadillac Owners Member
    Automobile(s): 2006 STS 1SG AWD, 1997 Concours Deville (sold)
    Jul 2007
    93
    I used a slide hammer. Drilled a 3/16 hole crossways through the dowel. Drilled a 3/16 hole crossways through the end of the slide hammer rod (1/2 inch OD rod). Put the slide hammer rod down into the dowel. Insert a really tough 3/16 diameter pin (phillips screwdriver shank). Make sure you leave lots of meat above the cross-drilled holes. You'll have to beat the hell out of them to get them out.
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by z06bigbird;
    You put air in tires?!?!?!?
  12. Remove Advertisements
