Code T061 What Is It? How To Diag?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Code T061 What Is It? How To Diag? in Cadillac Engine Discussion; ?????...
    1993 eldorado green1's Avatar
    1993 eldorado green1 is offline Cadillac Owners Fanatic
    Apr 2004
    michigan
    40
    176
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Code T061 What Is It? How To Diag?
    ABS pump motor or pump motor relay fault....
    Does the ABS work and/or do you hear the ABS pump run?? Check the relay center for the relay and power to the ABS system.
