99 ELDO coolant level Question.
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, 99 ELDO coolant level Question. in Cadillac Engine Discussion; Yes I know it's been asked a million times, but I am still a little confused about something. So the ...
    AKETC is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    11
    Yes I know it's been asked a million times, but I am still a little confused about something. So the other day my check coolant message comes on. No bigge I forgot to tighten the cap before I took off and some sputtered out. So fill the tank back up. Sure makes it easy being a black tank to see where you are at. Anyway I add about a gallon and stop. Peaking in there with a flashlight trying to find the right level at 2 1/2" from spout. Mine seems to be further. even measured it. Well know the deal is the way the tank fills up it seems like I could add endless amounts off coolant as I add some it levels out to a certian level. Like the coolant is going somewhere, but only to a point. AM I seeing that wrong? It almost seems like I could never fill the tank to the rim(yes I know it not supposed to go that high) if I wanted to like a normal tank on my other cars. Where is the coolant going or have I just not added enough? It's not going out the over flow tube which is at a higher level. Or am I just seeing things.
    69
    82,287
    Re: 99 ELDO coolant level Question.
    It is going into the cooling system. You were lower than you thought. Keep filling it till it gets to the 2" mark. Rev to 3-4K a few times to purge any air in the system, then check it again after it cools.
    Oct 2006
    11
    Thanks Ranger I figured it out. You were right at that I was just lower than I had thought. I added so much that it threw me off.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,361
    Another satisfied member.
    lisekpl's Avatar
    lisekpl is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS
    Aug 2006
    Chicago, IL
    105
    I was just about to say that maybe you had one of those miniature black holes somewhere in your engine that was sucking up all your coolant. They do exist, seriously.
  8. Remove Advertisements
