Fuel Filter Location?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Fuel Filter Location? in Cadillac Engine Discussion; Anyone know where the fuel filter is located on a 95 seville sts? Thanks...
    kcjustsk8 is offline Cadillac Owners Member
    Feb 2004
    4
    Thanks
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Re: Fuel Filter Location?
    I believe it is:
    Under the car, on the drivers side, mounted the the outside of the frame rail, just below the rear door.
    It has a couple of quick disconnect clips the hold the nylon tubes on. Be careful and avoid any damage to the nylon tubes. Have a small bowl to catch the small amount of fuel that will leak out.
    -George
    Feb 2004
    4
    Thanks alot I will try it tomorrow.
    cjm8232 is offline Cadillac Owners Member
    Apr 2004
    7
    when do you reccomed changing fuel filter?
  7. Remove Advertisements
