Northstar average engine temp ?
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Northstar average engine temp ? in Cadillac Engine Discussion; I have a 1998 Deville, what is the usual engine temp? And what is a safe heat range for the ...
    TexasCadillac Guest
    SmileNorthstar average engine temp ?
    I have a 1998 Deville, what is the usual engine temp? And what is a safe heat range for the engine? thanks TexasCadillac
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: Northstar average engine temp ?
    This varies widely but 195-215ish.
    STEVEHO is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Jan 2006
    Texas
    16
    My 99 Deville almost always runs between 199 and 205 degrees. The hottest I've ever seen it was 209 while sitting,idling, in a Houston traffic jam for over an hour in August.
    johnrgregory is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Jan 2006
    Utah
    107
    My 99 DeVille is about the same as SteveHo. Rarely needs to kick in the fan.
    69
    82,162
    My '97 ran a consistent 206 (summer) and 213 (winter). Cooling fans don't even come on till 224 or 225.
  8. Remove Advertisements
