help 2000 deville servive engine light
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, help 2000 deville servive engine light in Cadillac Engine Discussion; hello i have a cadillac 2000 deville no dts no dhs my service engine soon like came on i called ...
    gmello76 is offline Cadillac Owners Member
    Apr 2004
    11
    hello i have a cadillac 2000 deville no dts no dhs my service engine soon like came on i called onstar and they do a dianogstic check they told me it came up power train and to take it to the dealer in 7 days. some times my rpm run a lil higher and some times it stalls out at the stop light with the engine being warm or cold and i get hesistaion and yesterday it sumbled a lilttle bit it onlyhave 57k miles on it i was wondering could it be a sensor something i hope its not the transgoing out because that would be a shame. if there was a problem withe the trans would it come up on the dash because it does have that option according to the owners manuel and some times i have to give it gas before it starts whats up with the northstars acting like this i head this engine is good for 200k miles
    any help is greatly loved thank you
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: help 2000 deville servive engine light
    I dont know about the RPM running higher, but I would certainly not worry about the transmission at this point. It sounds like the Crankshaft Position Sensors due to your stalling. This is a very common problem on 2000 and newer Northstars and your dealer should know how to fix it easily.
    OlManRivah's Avatar
    OlManRivah is offline Cadillac Owners Fanatic
    Mar 2004
    Central Virginia
    112
    Do a Forum search using "Stalling". This should give you some ideas. Also, the specific OBD-II codes should help. Better than "Power Train".
    Apr 2004
    11
    Quote Originally Posted by Playdrv4me
    thanks buddy for the advice i never knew this car had so many sensors do you know how much they usaully charge for a job like that at the dealer ship Crankshaft Position Sensors job i hope not that much the deville is still a great car
    Smokey's Avatar
    Smokey is offline Cadillac Owners Fanatic
    Dec 2003
    Lufkin, TX
    119
    SmileRe: help 2000 deville servive engine light
    I too had the same problem on my 2000 Deville. I removed the air intake tube off the throttle body. I cleaned the throttle body and everything in there I could get to. No more sticky from idle gas pedal and no more hard to start/stalling. Been running fine every since. My Deville has 94,000 on it.
    Apr 2004
    11
    Quote Originally Posted by Smokey
    thanks for reply
    where is the throttle located is it that black box with the big hose coming from two screws what did you use to clean it chemical spray did yo lac stall at the light did you get a rotten egg smell to around the lac holla back
  9. Remove Advertisements
