94 eldo pcm code P083
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 94 eldo pcm code P083 in Cadillac Engine Discussion; this is crankshaft to ignition module failure....can anyone tell me what this means..........car fails to start at times.........and check engine ...
    jameswinburn is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    37
    this is crankshaft to ignition module failure....can anyone tell me what this means..........car fails to start at times.........and check engine light comes on from time to time.......this is the only code that is current.....thanks.........
    hue's Avatar
    hue
    hue is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Mar 2006
    Atlanta, Georgia
    28
    21
    Re: 94 eldo pcm code P083
    its probably either ur crankshaft position censors A and B need to be replaced or ur ignition control module is bad>>!!!!both are easy fixes!!
