Oxygen Sensors......Need help soon!!!
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Northstar Engines and System Technical Discussion Discussion, Oxygen Sensors......Need help soon!!! in Cadillac Engine Discussion; Oxygen Sensors............Need help soon!!!!!!!!!!!! I have a 1997 Eldorado (ETC) which I recently had a blown head gasket fixed. Time ...
    eldo is offline Cadillac Owners Member
    Aug 2003
    17
    ExclamationOxygen Sensors......Need help soon!!!
    Time Certs and the works done.
    I just had four oxygen sensors replaced yesterday, today the Service
    Engine Soon light came on. I ran the dianostic and it gave me the same
    four oxyen sensors I just replace a day ago.+ a MMM-B2150 CODE.
    I called the machanic that installed the sensors and told him what happened and he seems to think that it is my Catalytic Convertor causing the
    problem.
    Any help will be appreciated!!!!!THANKS IN ADVANCE
    Eldo
    P.S. Just want to say what a Great forum this is!!!!!!!!!!!!!!!!!
    egow is offline Cadillac Owners Member
    Apr 2004
    3
    Re: Oxygen Sensors......Need help soon!!!
    Had something similar happen to me with a past GM vehicle where a clogged fuel filter caused the O2 sensors to go bad along with the catalytic converter. The good new for me was the catalytic converter was covered under the factory warranty up to 80,000 miles instead of the standard.
    SevilleSTSJerome is offline Cadillac Owners Member
    Mar 2004
    49
    Can you please post the out come of your problem.......I just replaced all four of the O2 sensors in my 96 STS and so far the light hasn't been back on but who knows it might come back on next week so I would really like to know the out come. You know three of the O2 sensors are very easy to change but the fourth one that's by the fire wall behind the coil was hell to change....I had to removed the coil and the blower motor just to have room to get to it (are you sure your mechanic changed that one?) did you see all four of the old ones? Keep me posted my friend and I hope everything works out for you as well.
    Peace
    Sep 2003
    Metro ATL
    4,854
    I would expect O2 sensor problems to set a "P" code?.
    Are your "new" O2 sensors GM parts?
    Clear your code and wait for it to reset.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Agreed with Jim....
    It could have been coincedence or somethign... WHat I owuld do is take it out for a few good WOT blasts and see if that doesnt help..... Things need cleaning and thats the easiest and most fun way to do it!
    Aug 2003
    17
    Thumbs upRe: Oxygen Sensors......Need help soon!!!
    Yes, they are all GM Cadillac parts,, or that's what the mechanic told me.
    The one's from the dianostic were "P0135, P0141, P0147 and P0155. Also
    I got a MMM-B2150.
    WOULD LIKE TO THANK YOU ALL FOR YOUR HELP AND SUGGESTIONS;
    I WILL LET YOU KNOW THE RESULTS!!
    THANKS AGAIN GUYS!!!!!!!!!!!!!!!!
    Eldo
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by eldo
    I got a MMM-B2150.
    Eldo
    Check your fuses; all your "P" codes relate to "O2 sensor heater performance" problems. I have no idea where 'your' fuses might be located because my Service Manual is for a Seville. Under the hood is a good place to start. Look for a fuse that is labled something like "OXY SEN xx".
    Your "B" code relates to the RF mirror circuit.
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,121
    They are all O2 sensor heater codes. Seen aftermarket O2 sensors cause this. On OBDII systems you really need the GM parts. 4 GM O2 sensors can push $4-500 pretty easily....just for the parts.
    Fuse could be blown on the heater circuit....maybe. Would have to look it up.
    Logan
    www.airbagcrash.com
    www.logandiagnostic.com
    Aug 2003
    17
    SmileRe: Oxygen Sensors......Need help soon!!!
    Fuses are good, sensors are GM....I just don't want to buy a new catalytic
    converter to find out it's not the problem!!
    Thanks again Guy's for all of your help!!!!!!!!!!!!!!!!
    eldo
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    eldo,
    DO NOT replace your catalytic converter. If the converter was degraded you would have retrived DTCs P0420 / P0430. If your ho2s fuse is good like you say I would check your ho2s G-250 ground circuit, this ground circuit is related to all 4 sensors, I will be willing to bet it was left loose when the tech replaced your headgaskets. Lets us know what you find.
    Frank T
    Mar 2004
    49
    I ordered all four of my O2 sensors from GM Parts Direct and they were like under $40 each (the dealer wanted $117 for each one) I also received them in five days from the day I ordered.
    Peace
    Feb 2003
    Franklin, TN
    1,121
    I think FrankT might be right. Looking at the codes/diagrams....all use ground circuit 250. The actual ground is G109. G109 is located 'left hand rear corner of the engine, near the park/netural switch.'
    I dont think the cat is bad.
    Also, it would be very easy to put aftermarket O2 sensors in and call them GM ones...
    Logan
    www.airbagcrash.com
    Aug 2003
    17
    I took the Cad to Midas Muffler this morning and they said that the Catalytic
    Converter had no cracks and was good. (This was before I read the recent
    post on the forum). Anyhow, he asked if the machanic that put in the oxygen
    sensors clear the codes with a scanner after he finished. I told him I thought
    that he did, but wasn't sure. So cleared them (P0,,codes) with his scanner.
    So for the "Service Engine Soon" light is out. I sure hope that it stay that
    way!
    I sincerely thank all of you for the very helpful support that was given on
    this forum and God Bless everyone of you!!
    Thanks again,
    eldo
  16. #14
    Aug 2003
    17
    Hi Guy's,
    Today I drove the Cad about 26 miles and the "Service Engine Soon" light
    has not come back on since the guy at Midas cleared all of the old codes
    from the oxygen sensors. I hope that this is all that was wrong!!!!
    Thanks again for all of your help, much appreciated!
    eldo
  17. #15
    Aug 2003
    17
    Well the "Service Engine Soon" light came back on today after two days of
    being off. Guess I will have to start all over again, no luck!!
    Will keep everyone posted as to everything turn's out.
    eldo
  18. Remove Advertisements
