I got a present from summit racing today...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Northstar Engines and System Technical Discussion Discussion, I got a present from summit racing today... in Cadillac Engine Discussion; 24ft of 2.5" tubing and 4ft of 3" tubing... let the fun begin folks! forming the 3" into my rectangle ...
    fubar569 is offline Cadillac Owners Fanatic
    Automobile(s): 82 fleetwood - 97 deville
    Feb 2006
    452
    forming the 3" into my rectangle is about 15-20% complete, with a little under a foot of the 4ft section done. from here i will cut into sections and weld as appropriate to make my new crossover eliminator...the 2.5" is for the rest f the way back...will have an X pipe somewhere in there too...
    oh i did eliminate the mufflers...now till complete is all stock with no cat, resonator, or mufflers and my god does she sound badass!!!
    Feb 2004
    FL
    2,250
    Re: I got a present from summit racing today...
    True duals then?
    Remember- x pipes only work on equal length exhausts.
    blackdog's Avatar
    blackdog is offline Cadillac Owners Member
    Automobile(s): 02 Eldo, Back to Black
    Dec 2005
    Arizona, Valley of the Sun
    32
    keep us posted on how it woorks out. pics and audio would be fun too.
  5. #4
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    also how the heck are you going to fit an x pipe on that beast
    my STS has more room underneath than the 97 Deville and i wouldnt even attempt that...
  6. #5
    Feb 2006
    452
    Quote Originally Posted by CadillacETC1997 View Post
    very carefully is the plan...i know its very close quarters...plan is for dual 2.5" from front to back and out the tips...
    i wasnt aware of the equal length thing...but i do know an X has a distinctive sound and that was what i was looking for...would an H be better suited or should i not bother and run them both individually straight back?
  7. #6
    Feb 2004
    FL
    2,250
    IMHO, best sound is equal lengths with an X.
  8. #7
    Oct 2005
    15,987
    imho stick with 3 inch all the way back
    it sounds PLENTY nice, listen to mine...
  9. #8
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Whats an x-pipe setup?
  10. #9
    Oct 2005
    15,987
    just what it sounds and what an x looks like...
  11. #10
    Feb 2006
    452
    Quote Originally Posted by eldorado1 View Post
    my 02 GT had that setup...loved the sound with a pair of 40 series flowmasters...
    i love the way yours sounds ETC, but im also going for more power (however probably very little) by eliminating that stock crossover pipe...the duals is a natural progression after that and the X pipe is a given. I am going to re-use the heatshields from my stock cat and probably enclose my X in that to form my new "cat" for PA Visual inspection Just incase my uncle decides to be a poopy head...the issue is going to be how to lengthen the back bank to the same as the front and then install the X section...i'm sure i'll get that one figured out when i start pulling it apart...
    Oh, Pics of crosover eliminator in progress...
    top is 3" pipe in process of getting the shit kicked out of it into a rectangle of roughly 1" by 4" Inner dimensions (might be larger - havent measured yet) - the middle is a (99%) completed section of rectangular pipe for crossover elimination - third object is the 1" square steel stock that i am beating the pipe around/onto/with/etc...makes an excellent ramrod...lol
    this is a look down the (99%) completed rectangular pipe:
  12. #11
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    I was just thinking to myself...
    If your planning on running a "true dual" setup, where's the second cat gonna go, and how are you going to integrate it into the emissions system? Or are you just gonna go catless, and run an O2 simulator?
    Edit: Missed the "no cat" part of your first post.
  13. #12
    Feb 2006
    452
    Quote Originally Posted by danbuc View Post
    second cat? there's only one underneath my car...and i've looked several times...only 1...and it's gonna be gone too...and i will be running an O2 sim from a LS1 camaro
  14. #13
    danbuc's Avatar
    Mar 2004
    Mahwah, NJ
    31
    3,703
    The reason I asked was if you were planning on keeping the cat, you would need two being that your running two separate pipes back to the car. Since your not running a cat, it's a non issue.
  15. #14
    Oct 2005
    15,987
    wow...
    what are you gonna do use a hammer and blow torch to built and install this?
    i mean i realize everyone doesnt have access to a pipe bender like i do, but you realize that if your looking to gain every bit of hp you can from this, the roughness inside the pipe with cause more turbulence as it exits the pipes and therefor your gains will be less...
  16. #15
    Feb 2004
    FL
    2,250
  17. Remove Advertisements
