N* Oil Cooler And/or Tranny Cooler
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, N* Oil Cooler And/or Tranny Cooler in Cadillac Engine Discussion; 1994 N* 4.6 L. Does it have an Oil Cooler? Location? What provides the cooling? I know the 4T80E transmission ...
    C170B is offline Cadillac Owners Fanatic
    Automobile(s): '64 Cpe Deville, '94 Concour,2012 Prius C, 2010 RAM 1500 red
    Jan 2004
    St.Louis, MO
    163
    1994 N* 4.6 L.
    I know the 4T80E transmission is just about bullet proof . I have 175K and it has never missed a shift. The normals trans cooler lines route through the coolant radiator. Has anyone any knowlege of adding an aux trans cooler for the N*. (i.e. Extended mountain driving at high speed) ?
    regards
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: N* Oil Cooler And/or Tranny Cooler
    LOL They're only bullet proof if it's not mine. I have the ONE single unit that failed very prematurely. Just my luck I guess.
    I asked my trans guy about cooling and he told me that he felt they were very adequately cooled. He also said he's never seen one with heat related damage.
    Does that help?
    lisekpl's Avatar
    lisekpl is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS
    Aug 2006
    Chicago, IL
    105
    I concur, don't fix what's not broke. I was also told that even for heavy duty applications, the cooling is sufficient.
    JMWarren is offline Cadillac Owners Member
    Nov 2003
    51
    Some of the 90's devilles had a towing package that included an auxiliary trans cooler if I'm not mistaken. You might be able to adapt this part to work on your car...
    Eldobroken's Avatar
    Eldobroken is offline Cadillac Owners Fanatic
    Feb 2004
    164
    Quote Originally Posted by codewize View Post
    Does that help?
    LOL mine too at 80k and it was maintained. The internal coupler that holds the shaft broke and wasted every seal i put in. $3500 later its great. Well the tranny is
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    Quote Originally Posted by C170B View Post
    1994 N* 4.6 L.
    regards
    I replaced my oil cooler with a cooler 3 times the capacity, as the OEM. The stock oil cooler is a joke. I got the same brand so it would mount at the same location. As I am sitting here, I can't remember the brand but it is common. I can say, it has a rounded edge, and about an inch wider.
    I changed my oil today & it took 8 quarts, due to the larger oil cooler.
    ( note)..... Be sure to fill the oil filter with oil before installing to avoid that lag in oil pressure at the first start. The filter will take 3/4 of a quart.
  9. Remove Advertisements
