02 Deville Overheating
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 02 Deville Overheating in Cadillac Engine Discussion; i KNOW THIS HAS BEEN TALKED ABOUT A MILLION TIMES BEFORE BUT NONE ARE TOO SIMILAR TO MINE OKAY HERE ...
    THE VILLE is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    29
    i KNOW THIS HAS BEEN TALKED ABOUT A MILLION TIMES BEFORE BUT NONE ARE TOO SIMILAR TO MINE OKAY HERE GOES I GOT AN 02 DEVILLE BEEN OVERHEATING JUST GOT A NEW THERMO AND NOW ONLY OVER HEATS WHEN DRIVING I COULD SIT IN THE CAR FOR HOURS IN PARK AND IT WILL STAY AT NORMAL TEMP BUT AS SOON AS I DRIVE IT WILL HEAT UP QUICK IF ANYBODY HAS ANY CLUE AS TO WHATS WRONG PLLEASE LET ME KNOW JUST FLUSHED THE COOLANT WITH TABS AND OIL CHANGE OH YEAH IF ITS OVERHEATING AND I PULL OVER AND REV THE ENGINE A LITTLE THE TEMP WILL GO BACK TO NORMAL PRETTY QUICK THANKS
    Sep 2003
    Metro ATL
    4,854
    Re: 02 Deville Overheating
    Water pump drive belt, or belt tensioner, or both.
    Apr 2007
    29
    So Pretty Much Easier To Replace The Whole Water Pump
    68
    81,928
    No, just check the belt tensioner to be sure that it is not rusted at the pivot and not providing enough belt tension, thus causing the belt to slip and the pump to turn slower.
    Caddys 32's Avatar
    Caddys 32 is offline Cadillac Owners Member
    Automobile(s): 2002 Deville base
    Jan 2012
    Ravenna OH
    37
    24
    my 02 deville not over heating but just replaced the tensioner cuz it was make n knock n noise but it wasnt bad but bearings were make n some noise so it did need a new pulley. the main knock n noise was come n from the water pump, ordered it off line 4 $25 n free shiping so just wait n 2 get it then mec. put n it on 4 $110 sounds like a good deal said it will take like 2 hours 2 do. n im go n 2 have him put new thermastat on 2 while376302_234438636622538_100001692098104_572652_2101772682_n.jpg every things apart.
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    296
    My 2000 Deville was acting very similar..It would be fine if it was idling in park..But as soon as soon as I would start driving it would rapidly start over heating..Turned out that it was the head Gasket/ Head Bolt issue..I guess when idling the pressure wasnt enough for the engine to "pop its top" But as soon as I would get on it and drive it the overheating bells would go off and everything...Change engine oil message would come on..And by this time I had already replaced the radiator, radiator cap, overflow jug, water pump and belt, thermostat, radiator hoses, coolant sensor and I also cleared all my coolant purge lines..So my biggest fear had come true... I hope it is not your head gaskets..But I have come to realize with these motors hope for the best but expect the worse...Good luck..Check your coolant purge lines..it cant hurt..it may not help but wont hurt to do..
    Sorry..I just realized i responded to a 5 year old post...
  9. Remove Advertisements
