Pcm part number ???
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Pcm part number ??? in Cadillac Engine Discussion; I think I may be having some problems with my 95 STS PCM, after diging it out it turns out ...
    first sts is offline Cadillac Owners Member
    Nov 2003
    Florida
    35
    SmilePcm part number ???
    I think I may be having some problems with my 95 STS PCM, after diging it out it turns out to be a Remanufactured one,,,,does anyone know what the origine part number would be ???? there is a near-by junk yard that has some but he needs the original numbers that start with 161 ???????? Thanks,,,,
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Pcm part number ???
    Does it have a removable chip? If it doesn't, it won't do you any good to pick one up at a junkyard. You would have to get a reman anyway and have it programmed at the dealer to get it to work.
    Nov 2003
    Florida
    35
    Yes it has a removable chip in it
    El Dobro's Avatar
    Sep 2003
    1,471
    You lucked out there, but can't help you with the original part number. The parts book only lists the reman part numbers.
  7. Remove Advertisements
