Spark Plug Wires - Idea?
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Spark Plug Wires - Idea? in Cadillac Engine Discussion; does anyone make an aftermarket set to fit the northstar vehicles? i see no listing anywhere but ACDELCO originals...i just ...
    fubar569 is offline Cadillac Owners Fanatic
    Automobile(s): 82 fleetwood - 97 deville
    Feb 2006
    452
    does anyone make an aftermarket set to fit the northstar vehicles? i see no listing anywhere but ACDELCO originals...i just believe they dont have/cant make/dont get the boots for the cylinder head side or something...
    not that they provide any better performance, but i had an idea...
    using taylor thundervolt or other suitable unassembled performance wires as a base...
    razor slice old boots on seam and remove wire.
    crimp terminal end on new thundervolt (or other) wire
    lay wire inside modified boot (modify for bigger wire) making sure end of terminal is lined up with stop in stock boot.
    silicone and/or glue boot to reseal
    done...
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Spark Plug Wires - Idea?
    OK.
    Try it and let us know if it worked.
    Feb 2004
    FL
    2,250
    magnacore makes wires for our cars......
    Feb 2006
    452
    Quote Originally Posted by eldorado1 View Post
    they do? well...it would be nice if they'd turn up on a search....lol
    EDIT: i have found 1 online distributor for the 8.5mm wires - alamo motorsports...153.xx and free shipping
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    I like creativity.
    Ed
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    37
    1,317
    Autolite Professional has a set that is an exact fit for our cars. I was in a pinch once and GMPartsDirect screwed up my ACDelco wire order, and I needed the car for a long trip, so had to go local. The Autolite Pro wires were actually very good. The wires were numbered, like the ACDs, they were direct fit/length, and were even pre-greased like the ACDs. They're still running strong on the '97.
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Duralast at autozone
    misfit6794 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Deville (sold), 2000 Mustang GT
    Jan 2007
    Jersey
    32
    1,300
    I thought I remember someone saying that the acdelco wires are actually the best ones to use, i may be wrong. I got a wire set at napa i think they were 7.5 or 8 mm, anything will be better than whats on there, if they are the originals.
    jadcock's Avatar
    Jan 2003
    North Carolina
    37
    1,317
    I believe the ACDelco wires are 7mm. The Autolites I got are 7mm (I think). They fit the same in all the wire looms and slots, so I know they're the same size, whatever size that is. I think it's 7mm.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    They make sets designed for the N*. Search, there are cheaper places to buy them than direct from Magnecor.
    69
    82,173
    People have reported problems with some after market wires. A/C Delco seem to always work. I'd recommend them.
    Jan 2007
    Jersey
    32
    1,300
    I knew my memory was somewhat decent. I put on some napa ones and they worked fine for 2000 miles before i sold it.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Given the lengths we're working with, (pre-COP ignition) considering voltage and amperage drops and large flame kernel platinum padded plugs, insulated coat hanger wire is good enough.
  16. #14
    jadcock's Avatar
    Jan 2003
    North Carolina
    37
    1,317
    Quote Originally Posted by submariner409 View Post
    Considering only spark performance, that's probably right. But many folks have reported other problems that seem to all stem from EMI. There's a lot of electrical equipment under the hood, and ACDelco wires, in general, seem to be the best at preventing electrical interference.
  17. #15
    Feb 2006
    56,590
    Agree, absolutely.......the coat hanger wire thing was a jab at aftermarketer hype. BTW, I run quite a bit of electronic equipment on my boat, which is powered by a tricked Olds 455 ('70). The spark is supplied by a Pertronix/Delco distributor, Accel coil, and Accel 8mm/500 ohm/ft. wire firing NGK Iridium resistor plugs, and I have no interference problems. You can take an AM pocket radio, tuned between mid-band stations, and use it as an EMI/RF receiver. If the radio buzzes anywhere other than right at the sparkplug connector boot, you have a leak.
  18. Remove Advertisements
