G-Northstar Intake Plug
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Northstar Engines and System Technical Discussion Discussion, G-Northstar Intake Plug in Cadillac Engine Discussion; I found a nice little plug for the intake tube that allows the removal of the intake silencer or resonator ...
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    37
    1,317
    I found a nice little plug for the intake tube that allows the removal of the intake silencer or resonator or whatever it's called. No performance characteristics are expected to change, I just wanted to clean up the engine bay and make transmission fluid and air filter inspections much easier. I guess all the G-platform Northstar cars have this setup? (98+ Seville and 00+ DeVille)
    It's a rubber "quick connect" product designed for connecting lengths of PVC piping (rather than using PVC unions or elbows). But they also had plugs, or caps. The Quick Cap for 2" PVC pipe fit VERY snugly in the intake tube hole...almost like it was designed for it. Tightly enough for it to never fall out, but it's not so crammed in there so as to cause a deformation in the cap or intake tube and create an air leak. It's really a perfect size.
    Found it at Home Depot. It was a buck and a half or something.
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Re: G-Northstar Intake Plug
    That's exactly what I used....bought if from Home Depot. Except I flipped it the other way around, so that the bottom was almost flush with the inside of the tube. That way, you don't have air rushing pass a large opening, since it's sits almost flush inside. Just a thought. Also, you might want to use some glue as well. I tried just using a metal band clamp, and one night on my way to pick some food up at the Outback, the plug came loose and logged itself flat up against the maf screen bogging the engine down until it stalled. Kinda threw me for a loop at first since I had no idea what happened, then I looked at the intake tube and saw the hole. At that point, I got some high strength RTV and lined the outside of the plug before I set it back in place. Hasn't moved since.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    Nice.
    Ekindler0584 is offline Cadillac Owners Member
    Automobile(s): 2001 SLS (Diamond White)
    Dec 2005
    Columbus, OH
    32
    81
    I made mine originally out of two circles of pvc cut at different sizes. It felt real secure... But one night as I was getting on the freeway, manually shifting, and really getting on the gas... And it popped out!
    Needless to say, the engine started bogging down, and I had to pull over to find the cap and put it back on. Since then, I have added an extra piece of pvc, so that it is three layered circles, with the middle one a quater inch thick and a quarter inch smaller than the two outside pieces... With a thin strap around it all to keep it from popping out...
    So make sure yours is secured! (That is, if you always drive your caddy like you stole it!)
    jadcock's Avatar
    Jan 2003
    North Carolina
    37
    1,317
    Thanks guys for the comments.
    Good comments about it becoming unsecured. That's actually why I installed it how I did...the "top" of the plug has much more deformity resistance than the "bottom" (hollow) end...simply because the top is where the flat of the cap is. I think the only way it could fall out is if it popped OUT, rather than getting sucked IN. But some rubber glue/RTV couldn't hurt. And if I do that, I might as well flip it to create the smoothest surface possible, as you suggested, Danbuc.
    Edit: and I really don't want this getting sucked in. On the 2000+ engine, this is BEHIND the MAF, so if it did get sucked in, it'd lodge itself against the throttle butterfly, possibly blocking it open (dangerous). After thinking about this for about .3 seconds, I WILL go ahead and use some CA.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    I'm scratching my head. What the heck are we talking about here. First of all what is a G platform Northstar? Secondly my car doesn't have ANYTHING that looks like that. My trans dipstick is wide open. No problem accessing it at all and my air filter box is totally exposed. No problems whipping off the couple of wing-nuts for inspection. Of course I did have the Volant box on there which made even more room but I'm talking about with the factory air box.
    Is that a Seville? because my overflow tank isn't even on that side of the car.
    jadcock's Avatar
    Jan 2003
    North Carolina
    37
    1,317
    So the engine compartment on your '01 DTS looks totally different from that? I thought all G-platform Northstar cars (meaning 98-04 Seville and 00-05 DeVille) looked like that under the hood.
    The Seville (beginning in '98) has a large resonator/silencer box that "plugged in" to the intake tube where my plug is. It as a loose slip-fit at best, and I didn't like the potential for dirty air getting in there anyway. And I did CA the plug to the tube, so it has an AIR TIGHT seal now (and won't come out).
    If you could provide a pic of the underhood of your '01 DeVille, I'd love to see it. That would be my mistake if it's completely different. You learn something everyday, even if you think you already knew it.
    Edit:
    G-platform is the structure which began with the '95 Aurora and Riviera and which underpins the 98-04 Seville and 00-05 DeVille. This is a short article about it: http://en.wikipedia.org/wiki/GM_G_platform_%28FWD%29
    This following Wikipedia article claims that the recent FWD Cadillac models were still technically K-platform cars, though does admit that it's based on the G-platform: http://en.wikipedia.org/wiki/GM_K_platform_%28FWD%29
    The 1998 Seville is generally referred to as being on the G-platform, with the DeVille joining it in 2000. If that Wikipedia article is correct, and I guess that it probably is, the Cadillac platforms are still officially called "K"...although they share all the signature trademarks of the G-platform, like the battery under the rear seat. The 98-04 Seville also has the coolant surge tank in front of the driver side strut, just like in the Aurora. Since the Seville shared that design, I figured the DeVille would also, but I must be incorrect. Prior to 1998, the Seville's pressure surge tank was in front of the passenger side strut -- is that where it is on your '01 DeVille?
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Nope, my layout is totally different. I would love to provide pics but I think I deleted the ones I had so we'll have to wait until tomorrow when I get the car back from the tranny guy.
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    here it is
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Late 2002 (02-02) STS, Magneride, strut bar, CORSA, some tricks. Resonator in question is kidney-shaped box over driver's side transmission area. PITA for air filter changes/cleanups. Thanks for the butt plug tip...........Jim
    dwight.j.carter's Avatar
    dwight.j.carter is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Seville STS
    Aug 2004
    Des Moines, Iowa, United State
    37
    2,067
    Guys I hate to tell you this but that little add on plastic box is to help in cooling the air before it gets to the motor. I won't be taking mine off anytime soon. I would like to find a cold air intake for mine though made of rubber or plastic as the metal ones on ebay get to hot and don't work right.
    Feb 2006
    55,857
    Dwight......Think about what you just said about a sealed resonator box cooling air. Maybe theoretically, by damping intake pulses, but the route to the intake valve is already damped by the MAF, throttlebody butterfly, and the standing wave pulses in the tuned intake runners.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Yup, that's it al right. Thanks
    Quote Originally Posted by OffThaHorseCEO View Post
    here it is
  16. #14
    danbuc's Avatar
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Quote Originally Posted by dwight.j.carter View Post
    Haha..WRONG!
    It's a resonance chamber tuned to reduce induction noise in the intake system under heavy load.
    You are correct that a cai made out of metal that's placed in the engine bay is counter-productive. The best material to use would likely be white pvc piping. It's a light colored plastic, and therefor will not transfer heat very well...which is perfect.
  17. #15
    danbuc's Avatar
    Mar 2004
    Mahwah, NJ
    31
    3,703
    dwight.j.carter, I didn't mean to sounds like a complete douchebag in my response by the way. Long day, got written up at work, and have a generally sh**ty ass week. Sorry to come at you like that....just in case you happen to read it the wrong way.
  18. Remove Advertisements
