Anyone actually done a head gasket in car
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Anyone actually done a head gasket in car in Cadillac Engine Discussion; Ok - I know what the manual says - but following the manual is just too easy!!! Has anyone actually ...
    dac675's Avatar
    dac675 is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV, 2006 Stealth Gray CTS-V, 2001 STS
    Mar 2004
    Long Island, New York
    57
    Has anyone actually (sucessfully) done a N* headgasket change in the vehicle? I have a '97 Deville that appears to have a blown head gasket (~85K miles) and I am debating whether it is worth it to try and do it in the car. From a little bit of staining I see, it appears to be the rear head (closest to the firewall). I know that if I need to do timecerts, I will definitely need to pull, but I am debating doing the initial head removal in the car.
    I am looking for feedback from anyone who has (sucessfully or not) attempted this in the car. What was your outcome? Any especially impassable sticking points? Please don't quote the manuals for me - I am looking for actual experience here.
    Thanks!
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    37
    1,317
    Re: Anyone actually done a head gasket in car
    Yes. If nobody on here has done it, check http://www.caddyinfo.com forums. Multiple folks there have done head gaskets AND Timeserting in the vehicle. They all said it would have been easier with the powertrain cradle removed, but both head gaskets AND Timeserting CAN be done with the engine in the car. I believe both were on Sevilles, so a DeVille probably has even a little bit more room to work with.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The guru said he did one and would never do it again.
    I think your shooting yourself in the foot to try it that way. Why torture yourself when dropping the cradle makes it soooooooooooo much easier?
    Unless you have a large amount of perseverance you will probably never finish it if you do it in the car. Dropping the cradle will put you in the range of likely completion.
    lisekpl's Avatar
    lisekpl is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS
    Aug 2006
    Chicago, IL
    105
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    The head bolts have most likely stripped the block holes, and you will need a $1500 digital tool that typically on the dealer has.
    Find a newer total car!!
    Ed
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by z06bigbird View Post
    Ed
    ?? What tool are you talking about?? You need timeserts which cost about $350 for the installation kit. You can often find the tools used for about $200 and buy new inserts for about $50. They can be easily done by anyone with fair skills.
    68
    82,082
    Ed
    Huh?
    misfit6794 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Deville (sold), 2000 Mustang GT
    Jan 2007
    Jersey
    32
    1,300
    Hmmm, I don't see why you would want to try it, but anything is possible. When I stopped in at my mechanics when he was doing my headgaskets, he was timeserting the block. I could see this being way more difficult with the engine in car, especially the rear gasket. Its not really a repair to experiment with, unless you've gotta spare engine. No point in doing all the work if you are unable to do it properly, I think it would be really hard reach all 20 headbolts, to retap them.
  11. Remove Advertisements
