Torque Converter Clutch (P 0741 TCC stuck off) - Page 6
Page 6 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 76 to 90 of 309
Like Tree23Likes
Northstar Engines and System Technical Discussion Discussion, Torque Converter Clutch (P 0741 TCC stuck off) in Cadillac Engine Discussion; Have you pulled the DTC's?...
  1. #76
    68
    82,070
    Re: Torque Converter Clutch (p0741 tcc stuck off)
  2. #77
    fivo2fst4u is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    3
    Hi Ranger, i pulled all the codes from the instrument panel, and the only "Current" code is the PO741, by using the "off" and "warmer" buttons on the climate control. Is there another way to pull codes on this car that I'm not aware of? Thanks
  3. #78
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    The code pull is correct for your car. The P0741 is the TCC fault, which seems to be the main bugaboo, but if the transmission intermittently "slips" or seems to drop a gear, then there may be an impending fault in the 1-2 or 2-3 shift solenoids which control fluid pressures. There is a solenoid kit from GM which addresses this problem as well as installs an additional solenoid bracket/brace.
  5. #79
    Apr 2007
    3
    Quote Originally Posted by submariner409 View Post
    Thanks, but shouldn't it throw out another code for shift solenoids?
  6. #80
    Feb 2006
    56,237
    Yes.............notice that I hedged my bet on this one by saying ".....there may be an impending fault......."
    If the TCC is stuck off, and possibly tries to engage once in a while, the transmission would not seem to slip or drop a whole gear: it would drop about 300 RPM in 4th at above (?) 41 mph, then go back up, but its a gradual "shift", not abrupt.
  7. #81
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    When I bought my car in May 09 it had No Service Engine Soon light on. About a week later it turned on. Pulled codes from a shop, didn't know about the doing it myself, and the P0741 showed up. He cleared the code and it came back on the next day, I just left it on and drove. A few weeks ago I was going through the papers that I received from the previous owner and that code had shown up in July 08, I believe car was around 120k. I bought it with 124k on it and now I have 127k on it. Pulled codes yesterday from the dash and that code was shown. I cleared all codes and it has not come back on yet.
    When going to register the car I had to have it smogged, it passed easily. The light was not on but the code had to have been in the system since it came up a year prior.
    My avg mpg is 19.6 and on the freeway I'm getting 26/27mpg at 65mph Cruise Control engaged.
    Only thing I feel is that when in traffic and letting off the gas at about 6mph when it drops to 4/5mph I feel the car stick at that speed. When coming to a stop sign and not fully stopping but accelerating at that speed I feel a slight kick.
    The sticking feeling also happens when I am doing say 37mph and I take my foot off the gas and it drops to 35mph I feel a slight stickiness. I played with this (like an idiot) the other night on the hill to my house and as I went to put my car into Park (also drive and reverse) the car jerked really hard and it was idling at 2k, I turned it off then on and it was fine. Next day when exiting the freeway my car died while making the left hand turn at 15mph then I turned it on and got to work only to find the car jerking when putting it into park (D&R) but was idling at 1500 since then it hasn't done it again.
  8. #82
    tmo727 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac DTS
    Aug 2009
    35
    1
    my 2001 dts is throwing this code. I had the SES shut off because i failed emissions. So i have now driven about 150 miles and at all speeds and SES has not come back on. I have tried the brake test and the RPM's do rise slightly. Does anyone know how long it takes to complete drive cycle so i can go back in to emissions and try to retest before SES comes back on ??
  9. #83
    Feb 2006
    56,237
    If the SES light is not on and you did not reset the PCM (P) codes you should be good to go. Otherwise, give it a week. (The system needs time to reset in order to give a "ready" code to the test set.) BUT, you might get another TCC hangup in the meantime. Go for it.
  10. #84
    Jul 2009
    29
    968
    I reset my light on Thursday and it finally came back on Sunday Night/Monday Morning at about 130am. That was after about 160miles of driving. Thankfully this time it was the only code that showed up.
  11. #85
    thomassk is offline Cadillac Owners Member
    Automobile(s): Deville
    Aug 2009
    1
    I have a 1998 Cadillac Deville with a check engine light on with code P0741. The dealer service rep indicates that it is the transmission converter - cost of $3000 to replace. Would this prevent the car from passing a smog test in California?
    Thanks
  12. #86
    68
    82,070
    Yes. Clear the code and drive it in 3rd for a week before you retest it. DO NOT put it in D or once you get to 41 MPH the code resets and you'll have to start all over again.
  13. #87
    TAG617 is offline Cadillac Owners Member
    Automobile(s): 99 Seville SLS
    Jun 2009
    10
    I have this code as well. Along with a stupid "Check gas cap" which I believe is related to the EVAP system... Anyway, the P0741 code is wayyyy to expensive to get fixed but I have to pass MA emissions. Problem is I drive on the highway to and from work and usually heavy traffic. So putting it in 3rd for a week doesn't sound like a good idea. Am I right assuming that? Is there something else I can do to get it to pass inspection? If I clear it it usually takes a day or two to come back with normal driving. TIA!
  14. #88
    68
    82,070
    Quote Originally Posted by TAG617 View Post
    No. Won't hurt a thing, other than your fuel mileage.
  15. #89
    Jun 2009
    10
    Cool, i'll start tonight on the way home. As long as the code doesn't come back within the week I should be good for emissions?
  16. #90
    68
    82,070
    Yeah, that should do it.
  17. Remove Advertisements
