Torque Converter Clutch (P 0741 TCC stuck off) - Page 17
Page 17 of 21 FirstFirst ... 789101112131415161718192021 LastLast
Results 241 to 255 of 309
Like Tree23Likes
Northstar Engines and System Technical Discussion Discussion, Torque Converter Clutch (P 0741 TCC stuck off) in Cadillac Engine Discussion; Hi, Thank you both for the prompt responses. I got the code again a day after clearing. In addition the ...
  1. #241
    2008DTS is offline Cadillac Owners Member
    Automobile(s): 2008 DTS 2002 Deville
    Feb 2013
    57
    19
    Re: Torque Converter Clutch (p0741 tcc stuck off)
    Hi,
    Thank you both for the prompt responses. I got the code again a day after clearing. In addition the is only (1) other code, a IPM B0429. I think it has to do with the rear HVAC control or something as found on the forum. No big deal for me.
    I was hoping to hear from someone that had been able to clear the code without a transmission overhaul.
    Submariner, thanks for your offer to search your albums. I'm new, I will try to locate them as a start.
    Keeping my fingers crossed.
    Thanks,
  2. #242
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Click my username, open the profile. Left column, 2 albums down a bit. 118 pictures and diagrams of Northstar stuff.
    or ............ up ^^^^ in the Community tab, Albums. The red Seville.
    You might want to go way up into the top black bar and study the entire Cadillac Technical Archive. Very necessary info for every Northstar driver, most of it from a GM Powertrain engineer.
  3. #243
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    TCC stuck off situation can be intermittent. Telling by others' experience, it seems to gradually get worse though once it happens.
  5. #244
    Feb 2013
    57
    19
    Thanks for the response. Yes, I understand it can be intermittent that's why I questioned the outside temperature. The situation with me is slightly different. My TCC has never malfunctioned, or failed to go into OD. All of the failure test suggested in these threads were successfully completed. I wish I could find a reliable transmission shop in Southwestern Pennsylvania to just repair the seal that is causing the light.
    The only alternatives I have been given were:
    Rebuild from Cottman $3500.
    Cadillac Dealer suggested not to just repair the problem, but to install an overhauled unit, $4000.
    QUOTE=maeng9981;3310955]TCC stuck off situation can be intermittent. Telling by others' experience, it seems to gradually get worse though once it happens.[/QUOTE]
  6. #245
    Feb 2006
    56,884
    FWIW, TCC is NOT "overdrive". The transmission uses 4 gears - and 3rd is the 1.00:1 direct drive gear - 4th is 0.68:1 = overdrive. TCC is an emissions control that removes most of the last 300 or so rpm of slip between the stator and rotor - a gas mileage savings, therefore emissions-related. That's why a TCC fault will fail an emissions inspection.
    The "drop in a rebuilt GM unit" seems to be the preferred fix among Cadillac dealers in the DC area also. Monster Transmission in Florida will totally rebuild a tight 4T80E with locking converter for $2700, shipped. You install it or pay labor, core goes back.
  7. #246
    69
    82,287
    Quote Originally Posted by 2008DTS View Post
    Clearing the code is easy (I do it almost every drive). Keeping is off is not easy or cheap.
    Quote Originally Posted by maeng9981 View Post
    It WILL become more frequent.
    Probably not to far out of line. Most of it is labor. When the seal is replaced it is recommended that the TC also be replaced. How important that is, I don't know.
  8. #247
    d_snypa is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Mar 2011
    San Antonio, Texas, United Sta
    38
    5
    I got a stuck TCC code took it to the dealership they quoted me $4600. Took to another place without charging me they told me it may just be low on fluid. Checked the fluid it was low. Brought it up to level. TCC code gone. Saved $4584. Passes road RPM test as well.
  9. #248
    Feb 2013
    57
    19
    Quote Originally Posted by d_snypa View Post
    I had my fluid flushed at the Cadillac dealer then removed some of the fluid and added a bottle of Lucas. It has been out now for 1400 miles and counting.code was not present when I had the emissions test done and now I am good to go till August 2014!
    I have been told that any type if additive in a bottle that is meant to swell up the worn seals won't work on the TCC since the seal is made of silicone.
  10. #249
    Dave NYC's Avatar
    Dave NYC is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville (Base)
    Mar 2007
    New York City
    48
    185
    Re: Torque Converter Clutch (P0741 TCC stuck off)
    Bravo
  11. #250
    69
    82,287
    Be patient. It WILL return. You can clear the code and turn off the SES light, but rest assured, it will become more frequent. The good news is unless you have to pass an emissions test, you can ignore it.
    P.S.
    The code is caused by a leaky internal seal causing a very slight TC slippage, NOT by being low on trans fluid.
  12. #251
    Feb 2013
    57
    19
    Ranger, you are correct to code will reappear. I found a transmission shop south of Pittsburgh that was familiar with the problem. The overhaul still was $3500. , but he did offer to include the changing the leaky oil pan gasket. He knew they all leaked. He also said there are only two things that go wrong with the 4T80E is the SES light caused by the TCC or the car won't move. If I can, I will wait for the later to occur, since it is the same price to overhaul.
    Thanks man,
    P.S.
  13. #252
    Feb 2006
    56,884
    ............... changing the leaky oil pan gasket. He knew they all leaked.
    Oh, really ?? I maintain my STS plus two other Sevilles and a Deville (all in the 2000 - 2004 years) and none of these leaks a drop of anything .......... of the 4 cars, two were bought used, two off the dealer floor.
  14. #253
    69
    82,287
    The later is rare. The 4T80E is pretty solid, generally speaking. The TCC (P0741) problem can last forever and not cause any problems.Unless a HG fails, I don't plan on fixing mine.
  15. #254
    Feb 2013
    57
    19
    Quote Originally Posted by Submariner409 View Post
    My 2002 Deville doesn't leak on the floor either. On mine the engine oil leaks when driving and is blown back. I guess it won't rust...
    I agree, if it weren't for emissions in PA all would be good with an occasional reset of the SES light. At 130,000 I was getting the check coolant level message. Thought it was a head gasket. Turns out the float in the coolant tank was saturated and tripped the magnetic switch for coolant level. You can change the switch (external on the tank) that didn't work. I then replaced the tank and the switch was included $85 Advance Auto Parts. A friend had the same problem on his 2002 shortly afterwards. He only had 69,000 miles, so I think it is a matter of age that causes the float the become saturated and fail.
  16. #255
    69
    82,287
    Re: Torque Converter Clutch (P 0741 TCC stuck off)
    Yeah, I think the float thing is somewhat common and definitely age related. I get it every once in a great while. If it starts to get common I'll replace the tank.
  17. Remove Advertisements
