Water Pump Drive Pulley Removal
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, Water Pump Drive Pulley Removal in Cadillac Engine Discussion; Ok... I'm working on a FWD Northstar engine, space is unlimited as it is on an engine stand. How do ...
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    QuestionWater Pump Drive Pulley Removal
    Ok... I'm working on a FWD Northstar engine, space is unlimited as it is on an engine stand. How do I removal the water pump pulley from the intake camshaft on the even (front) side? I've removed these things before but this one will NOT come off. I've hit it with about 8 kinds of penetrating oil, I don't want to warp the camshaft so I'm not going to heat it excessively.
    Last time, all I did was put a small puller onto the ring at the outer side of the hub of the pulley (hub is metal, pulley is plastic), and off it came.
    Any better suggestions?
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    34
    963
    Re: Water Pump Drive Pulley Removal
    naa, yeah like you said, clamp on the inner metal portion, just borrow a pulley removal kit from Autozone, Advance, NAPA, otherwise get a larger pulley remover with more arms (the 3-4 variety) and just clamp on the plastic, it'll come off and even if you break it they're not expensive to replace...
    Feb 2004
    FL
    2,250
    Rent a power steering pulley puller from Autozone (or Advance). It will slip on the metal collar and won't break anything.
    Once they snap they'll slip right off (relatively speaking)
  5. #4
    Apr 2005
    Oakland County, MI
    33
    1,320
    Power steering pulley puller. Ok. Will try that. I assume it has a fixed jaw size?
  6. #5
    Feb 2004
    FL
    2,250
    yes, it just slips on the collar. It will look something like this:
    http://www.stu-offroad.com/steering/pspump/psp-2.jpg
  7. #6
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    It takes the same puller as the p/s pump pully.
  8. #7
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Good luck.
    Ed
  9. #8
    RickyHenry's Avatar
    RickyHenry is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville; 1999 Seville
    Mar 2008
    134
    Quote Originally Posted by Raze View Post
    not expensive to replace? try $65 to replace the plastic pulley. I broke mine just now... the junk yard wants $125!!!! for one.
  10. #9
    David Olinger is offline Cadillac Owners Member
    Automobile(s): 1999 seville
    Jan 2011
    Spokane, Washington, United St
    33
    3
    How do you get the pully back on once u get it removed? I am changing the belt, pump, and pully right now. Got everything disassembled but the pully is 40 bucks and I don't want to have to buy a new one by breaking it by beating it back on...any suggestions?
  11. #10
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
  12. #11
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    Quote Originally Posted by David Olinger View Post
    Don't even come close to trying to force the pulley onto that intake cam snout. You'll be buying a whole new left head valvetrain if you do.
    Use either the GM pulley removal/install tools ($300), the posted Harbor Freight (or NAPA store) power steering pulley kit, or use a proper size/length metric bolt, greased washers, and nut to press the pulley back with the hub flush with the end of the cam snout. I assume the Torx-headed plastic cam protector button is removed. Look at the diagram for the idea of how to press the pulley back onto the cam.
  13. #12
    68
    81,755
    I'll echo that warning. Beat it on and a replacement pulley will be the least of your worries.
  14. #13
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    FYI folks:
    #3535846 - $53.36 (GM List price) -- $39 (forum member discount price)
    sannerj and sannerj like this.
  15. #14
    tjohnson20 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Sep 2010
    Nebraska
    4
    Does anybody know the size of the bolt needed to press the Cam Pulley back on the Cam shaft? I plan on using a bolt and washers as noted.
  16. #15
    Feb 2006
    55,566
    The bolt measures to be 7.94mm - probably an 8mm bolt, fine or medium pitch thread.
  17. Remove Advertisements
