Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Show off your Cold air intakes!
    darien99's Avatar
    darien99 is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    I was thinkin' about going down into the wheel well for my cold air intake, has anyone done this? Anybody have pics of their's?
    69
    82,278
    Re: Show off your Cold air intakes!
    Wheel well! Holy water injestment, Batman.
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
  5. #4
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    35
    963
    Ranger you crack me up dude...
  6. #5
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    I think the factory air system is totally fine until the actual air inlet behind the driverside headlight, which is smaller than the rest of the system.
    Someone here did a dyno with and without the entire factory air intake system and got a ~7HP increase though, so if you want you can just stick a cone filter in front of the throttle body and stick the MAF sensor in between. But that's kinda ghetto...
  7. #6
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Water? What's that?
    I've been running my cai 4" above the ground on my neon for about 200,000 miles now, not a single problem, and it dropped .3 off the 1/4. Since we're restricted on the amount of modification available for these cars, we have to make the best of each one. I'm not going to settle for those ebay intakes and call it good. I did that on my Dakota and ended up going a tenth slower. So I made my own and went .2 faster. BTW- the Dakota took air from the wheel well stock, I don't think they were too worried about water ingestion.
  8. #7
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Quote Originally Posted by weister42 View Post
    Well I don't have to worry about the MAF. I was hoping to stick most of the cone into the original air passage area- perhaps open that up.
  9. #8
    Jan 2006
    SE Michigan
    198
    I've enlarged the stock passages and when at the track add a 4" pipe that feeds from the grill. It's definately noticable over 60mph too. (dropped me about 1/10th and gained about 1mph in the 1/4)
    Rich
  10. #9
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    I just put my factory air box back in. I was looking for something and I had it all apart when I realized my installation job left a lot to be desired. Mostly the fault of Volant providing no way to mount the box to the car, poor cable routing for the PCM, mis-drilled holes for the PCM bracket, and no way to make a tight seal to the pass-through.
    SO I have a few things in mind. Most of the mounting got worked out today and I'm going to do something similar to the duct work thing that wydopnthrtl mentioned but I'm going to be more subtle and design something like the factory trumpet, just larger. That will all be integrated with the sealing solution I come up with.
    In addition to those changes I am also going to work with internal baffles while I have a dyno available. I'm going to do a run with the factory box first, other reason I put it back in. Then with the Volant, then some trick baffling. Whatever puts down the best numbers is what we keep. Then we do it all over again when the exhaust goes on.
    OH and BTW, going into the wheel well is a dumb idea. You'll suck water like crazy and the rotation of the wheel will pull air away form the intake during rotation. We are talking about Chrysler products above. The engineers over there are not geniuses.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
  11. #10
    Raze's Avatar
    May 2004
    Atlanta, GA
    35
    963
    Quote Originally Posted by codewize View Post
    The GM engineers aren't 'geniuses' either...
  12. #11
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    Quote Originally Posted by Raze View Post
    Exactly. After actually working for both, I'd definatly say Chrysler has the edge in the engineering department over GM.
  13. #12
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    So why haven't I (or anyone else with a Dodge) ever sucked water?
    FYI Dodge does NOT have intake sealing problems on every V6 they ever built like GM does. Dodge does NOT have blower motor resistor problems on every 8-10 cars, and if they did they're easily accessable, unlike GM. Dodge does NOT have ABS problems due to corrosion like most of the GM trucks. Dodge does NOT have an intermediate steering shaft rattle AT ALL where GM does on vehicles all the time, starting under 15,000 miles. You hardly ever see swaybar endlink problems with dodge, again you can watch 10-15K mile GM's come in under warranty with that nasty front end clunk. I never seen a HD Ram come in with an a/c compressor exploding because the truck couldn't handle having a plow on the front. Working for GM I now see this biweekly.
    I could go on forever. Point being Chrysler engineers may not be perfect, but they have a hell of a lot better idea of whats going then some other companies.
  14. #13
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    38
    1,317
    Quote Originally Posted by darien99 View Post
    You must be excluding the minivans. On the Chrysler minivan forum, that's probably THE most asked-about topic -- the swaybar end links and bushings that repeatedly fail. Our '03 has had three sets of both, in only 70k miles. Many others have the same story. Other than that, the van has been great. All vehicles have their own issues. It's nice that we have choices.
  15. #14
    fubar569 is offline Cadillac Owners Fanatic
    Automobile(s): 82 fleetwood - 97 deville
    Feb 2006
    452
    Quote Originally Posted by wydopnthrtl View Post
    Rich
    i have nothing now but plan on something similar to this once my hand gets better...
    i am also dreaming up a MUCH better solution to the traction control idea...tapping into the ETBCM or whatever is about next to impossible without major disassembly of the car just to get to it (least on my deville)...im thinking of doing a one-off and cutting into the wires in the wheel-well area for ease of install purposes...or doing 4 seperate modules located and mounted near each wheel well...
  16. #15
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    33
    194
    I was checking out the big area in front of the grille yesterday, I love that large amount of area!
    Now if we could only route pipe from the tb to that area, we could hang a huge K&N cone in there.
  • You may not post replies
