Results 1 to 4 of 4
Thread: fuel injectors???
    Jan 2004
    canada
    30
    76
    fuel injectors???
    should i buy after market injectors yes or no?
    example accel
    Jan 2003
    Minnesota
    319
    Re: fuel injectors???
    no
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by the little STS
    example accel
    The answer is no...but why would you be buying them?? If you think they will make the engine faster.....they won't. Putting more gas in with no other changes will not make more power. Period. There is no magic in the injectors...they just meter the fuel into the engine....the OEM injectors meter the correct amount and adding to that will not make more power....in fact, it will make less as the engine will be over-rich. If you think you need replacement injectors due to a sticking or failed injector then use the OEM injectors....they are matched precisely for the system...ESPECIALLY if you only replace one or two injectors...they need to match the rest of the injectors in the system precisely.
  5. #4
    Jan 2004
    canada
    30
    76
    bbob ur my hero
  • You may not post replies
