What Materials Are Used In Norhtstars ?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Northstar Engines and System Technical Discussion Discussion, What Materials Are Used In Norhtstars ? in Cadillac Engine Discussion; I would like to hear what you guys think of this idea. I was reading some reviews and found that ...
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    I would like to hear what you guys think of this idea. I was reading some reviews and found that :
    "maybe either an all aluminum engine or an all cast iron engine. The 4.6L has a cast iron block and an aluminum head, both materials have different expansion rates paving the way for blown gaskets or cracked heads. I tip my hat to Caddy for the post-2004"
    Is this right ? I knew that Northstar is all aluminum .I am confused a bit here .However what's even more confusing to me is that those GM Engineers don't have an idea of what an engine should be made of , combined and put together ? Just because reliability problems are addressed from using different materials .
    For my thoughts I would be happy if Northstars have cast iron blocks just like Vortec engine .
    Feb 2004
    FL
    2,250
    Re: What Materials Are Used In Norhtstars ?
    The 4.6L northstar is all aluminum.
    The 4.9L has an iron block with aluminum heads.
    The reason the 4.6L northstar blows headgaskets is because the aluminum threads in the block pull out (causing the head to be held on by fewer and fewer bolts) and/or the gasket rusts out due to improper maintenance of the cooling system.
    1997BlackETC's Avatar
    1997BlackETC is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Mercedes E63 Amg Station Wagon
    Apr 2006
    Florida
    58
    1,348
    I just thought of a preventative maintenance idea that would prevent head gaskets from blowing on the northstars. Run a heliarc weld around the head and the block, this would keep the head from ever lifting from the block. If by some freak thing the head gasket ever did go then, just replace the engine with a rebuilt one for $3295.00. I guess they my not be too happy with the core that was turned in, but, oh well, thats life.
    Dec 2003
    36
    4,388
    Thanks for your input . I see why Northstar gets headgasket failures quite often .If it were a cast iron thouse threads wouldn't pull out
    dratts is offline Cadillac Owners Member
    Jul 2006
    5
    Eldorado, I have a ton of respect for you due to the success you've had with your N* projects and the trans controller you built, but I think you have it backwards. Doesn't the 4.9 have an aluminum block and iron heads? I know that this is just the opposite of most iron/aluminum combos. I would be interested in the 4.9 if trick flow or someone made some good heads for them.
    Feb 2004
    FL
    2,250
    Quote Originally Posted by dratts View Post
    I think you might be right
    Apr 2006
    Florida
    58
    1,348
    Yes, thats right, Aluminum block and Cast Iron heads. Your probabley not going to see any aftermarket makers making special head for this motor as its just not a popular hot rod motor like the Rat and Mouse chevy motors.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,214
    Quote Originally Posted by 1997BlackETC View Post
    The first step in implementing that idea is to preheat the whole assembly to 500deg.F. That's the end of the gasket and any other sealer anywhere in the engine. That's got to be one of the most rediculous goddam schemes I've ever heard. You're not related to Al Gore are you?
    Don't mess with Binky Bear!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,214
    On a more serious note there are many examples of engines that have the heads cast with the cylinders or cylinder block and everything loads from the bottom. The Meyers and Drake Offenhauser, the Allison V1710, some Rolls-Royce Merlin versions, the Crosley Hot Shot are all enbolc with no head to crankcase joint.
    68
    81,914
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    The N* engine is Aluminum with cast in grey iron sleeves.
    The 4.9 has an aluminum block with iron cylinder inserts. Those are pretty cool in that you can replace one whole cylinder without having to rework the block. I was quite surprised at the first one I took apart.
    I rarely see a N* pull head bolts that didn't overheat due to inattention or lack of maintenance FIRST.
    Welding around the head is just a crazy idea, plus it wouldn't work anyway. The real pressure is nearest the cylinder where the bolts are, it could easily blow the head gasket completely loose in the center even if it was welded around the edges, not to mention the dozens of other problems that would create. I hope that was just a joke.
    Actually one of the best ways to hold a head on is by using studs insted of bolts, but it costs more and it can be more complicated... but that is another topic.
    The N* block and heads are all aluminum. There are lots of vehicles out there with cast blocks and aluminum heads that have little or no problem with sealing or thermal expansion variation.
    Don't believe everything you read.
    (except of course what I tell you )
    68
    81,914
    That battle has been fought before. There was a very lengthy and "heated" discussion between someone and our old Guru about this before. Since it involved the Guru, I doubt that it can be found with a search.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    dang...
  16. #14
    Feb 2004
    FL
    2,250
    ExclamationRe: What Materials Are Used In Norhtstars ?
    The end result of which was that studs do NOTHING to help the situation specific to the northstar, because the weak link will always be the block threads.
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,214
    Studs are also a big production problem. Sliding head gaskets down over studs is hard to do with automatic equipment. According to Bbob, the Cadillac Northstar heads, block, head gasket and capscrews were an interlocking engineered system. A big bone of contention was always what came first, the pulled threads or corrosion. I've always suspected the metalurgical properties of the die cast block. Uneven cooling is the bugaboo of die castings and the resulting nonhomogenous grain structure causes failed threads in my scenario.
  18. Remove Advertisements
