93 Eldorado
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 93 Eldorado in Cadillac Engine Discussion; can anyone give a little input on a possible shortcut to removeing the trans to change the flexplate and torque ...
    RWALSH5 is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldorado touring coupe
    Mar 2007
    Scranton pa.
    18
    93 Eldorado
    can anyone give a little input on a possible shortcut to removeing the trans to change the flexplate and torque converter,can I just remove the driver side frame bolts and possibly loosen the passenger side enough for the frame to tilt to gain access to the trans?I'm sure it will be easiest to just drop the frame,engine and trans all at one time right to the floor I was just hoping I could find a shortcut any help will be greatly appreciated thanks.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: 93 Eldorado
    You should be able to do it by dropping one side of the cradle. The wiring on the 93's is a pain and harder to remove than 97's. Dropping one side should save a lot of time.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,361
    Re: 93 Eldorado
    I don't think so. You can do the input speed sensor in the car, but no matter what the cradle has to be dropped for the transaxle. It wont clear it. You can do it with the engine in the car using an engine support fixture, I still think it's quicker to drop the whole powertrain.
