Swith Problem message - how to find which swithc
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Swith Problem message - how to find which swithc in Cadillac Engine Discussion; I am getting a "swich problem" message on a 95 Eldo - how do find out which switch is the ...
    Pvelasquez is offline Cadillac Owners Member
    Automobile(s): Eldo 95, 97, 83 Deville 91
    Nov 2006
    Salt lake City Utah
    49
    I am getting a "swich problem" message on a 95 Eldo - how do find out which switch is the problem. I have ran the codes and have two current "Closed Throttle Angle Out of Range [TPS]" and "Brake Fluid Level Low". Does anyone know how to id which switch. I was told by the shop mechanic thet the "Brake Fluid Level Low" was a bad sensor, the other message does not seem to relate to any switch.
    69
    82,263
    Re: Swith Problem message - how to find which swithc
    Sounds like both switches are bad.
