What did Cadillac do to get more power?
Results 1 to 15 of 15
Northstar Engines and System Technical Discussion Discussion, What did Cadillac do to get more power? in Cadillac Engine Discussion; Out of the later 4.6's like the XLR. The intake manifold appears to be different from our's..would this be a ...
    darien99's Avatar
    darien99 is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    32
    194
    Out of the later 4.6's like the XLR. The intake manifold appears to be different from our's..would this be a nice bolt on modification for us? Didn't they also go to a roller lifter setup? Any info/tips?
    Edit:I guess this should have been posted in northstar performance..
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Re: What did Cadillac do to get more power?
    The big kicker is Variable Valve Timing on all 4 cams.
    Not a "bolt on" of any sort.
    Some other things are different too, but I think the VVT is the primary difference.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    also the fact the motor is straight rather than inverse...
    it allows for better headers
    fwd N*s bottleneck is the xover pipe...
    68
    81,897
    Roller followers were added in 2000. Not for performance but for oil life and milage increase.
    I'll move this to the Northstar section for you.
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    32
    194
    Thanks for moving it Ranger.
    Didn't know about the VVT, and I didn't think about the exhaust manifold design either. You'd think with those improvements they would have seen a bigger gain.
    BodybyFisher Guest
    coil on plug also....?
    fpmesiIII's Avatar
    fpmesiIII is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS (167k)
    May 2005
    Western NY
    473
    yeah i heard lack of spark plug wires helped with increase gas mileage.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    FWD N* has coil on plug ignition since ... I think 2000... right Ranger?
    They just use a bigger coil assembly. There are two big coils as opposed to 8.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    Quote Originally Posted by ewill3rd View Post
    yes 2000 was first year for coil on plug ignition. I forgot to read the original posters post. thought we were discussuing the 2000 N* changes. my bad.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Right, cam followers, no lifters.
    68
    81,897
    Yup 2000 was the introduction of roller followers & COP ignition, but don't you mean 4 coils?
    BodybyFisher Guest
    Did they institute direct injection yet?, I think I recall the guru mentioning that it was coming. Audi is using direct injection, here is the description
    FSI is an ingeniously efficient fuel-injection technology that squeezes more power out of every drop of gasoline. By injecting fuel directly into the combustion chamber milliseconds before ignition, FSI creates instantaneous combustion.
    BodybyFisher Guest
    This is what I meant. EIGHT COILS, one for EACH cylinder.....
    The ignition utilizes a coil-on-plug arrangement, which maximizes spark energy, eliminates spark plug wires and improves electromagnetic compatibility performance. The ECM precisely commands ignition spark event and timing. Four pencil coils are assembled to a bracket for modular assembly, one module for each bank. During engine assembly, the coil modules are assembled to the top of the cam covers so that the coils fit into tunnels in the cam covers and cylinder heads, and connect directly to the spark plugs.
    See this article, it gives me a boner, Anatomy of an Engine - the New Northstar V8, specifically IGNITION SYSTEM
    http://autospeed.drive.com.au/cms/A_1569/article.html
  16. #14
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    I haven't seen it yet but I know Direct Injection is coming to the V6.
    The only DI engine I know of out there right now is the turbo engine in that little Saturn thing.
    The FWD N* ignition system is similar in design and operation to the RWD VVT models. It is just a different arrangement, but I know what you mean.
    They are doing a lot of things with some pretty high tech stuff here lately.
    It is actually quite amazing.
  17. #15
    darien99's Avatar
    Automobile(s): none
    Dec 2005
    Hazel Park, MI
    32
    194
    I noticed there's a different style intake plenum on the 2000+ motor. Was this design for more power or to be quieter?
  18. Remove Advertisements
