4.5 running like poop
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, 4.5 running like poop in Cadillac Engine Discussion; I have a 1990 DeVille with the 4.5 and it's running like crap. It idles a lot rougher than it ...
    gtm245 is offline Cadillac Owners Fanatic
    Jan 2004
    116
    I have a 1990 DeVille with the 4.5 and it's running like crap. It idles a lot rougher than it ever has and it just sounds rougher and a little louder than before. I just did an oil and filter change about 100 miles ago. Also, I usually use 89 octane with absolutly no problems (believe me I'm very meticulous about my car) but 2 tank fulls ago I filled up with 92 octane. It seemed to run a tiny bit better (smoother and a bit faster), but nothing that someone would notice if they weren't looking for it. Anyway, that was 2 tank fulls ago and on the last tank, about 80 miles ago (a couple days after my oil change), I went back to 89 octane. At first it sounded and felt like it always had when I had run 89 but then it started to get rougher and rougher. It started to get rougher and rougher after I had done a few WOT runs down the highway. Besides the usuall rough idle that I now have sometimes it stumbles for a few seconds after I start it up. All fluids are at the full mark, 2000 miles ago I installed a new fuel filter and air filter, it has a new serpentine belt, and 41,000 miles on it.
    Whats the deal? Is the rough idle and driving from using 89 octane while doing some WOT runs? I didn't notice any audible pinging or knocking. Fresh oil and filter, new fuel filter, the same 89 I've always run without rough idle so I have no idea what's causing this. Someone please help me.
    BTW I think I'll try the 92 octane again once I'm done with this tank of 89. About 11 more gal. to go and then I'll see if it was the gas. Where's BBoblynski on this one.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 4.5 running like poop
    Quote Originally Posted by gtm245
    Did you check the fuel pressure regulator...????
    Pull the vacuum line off the fuel pressure regulator while the engine is idling and watch the vacuum nipple for several minutes for any sign of fuel leakage.
    Check fuel pressure???
    The fuel did not likely hurt it or cause the problems you note.
    bbob was gone snowmobiling for a few days in Canada. This forum is NOT a full time gig....LOL
    Jan 2004
    116
    Fuel pressure is right at specs. so it can't be a fuel delivery problem? Any other ideas?
    Along with the roughness I now have, a while back I remember I started a thread about if I could use 89 octane instead of premium and if you remember I said my car made a weird engine noise that I couldn't describe. Then you (bbob) asked if it sounded like marbles in a can with a rag wrapped around it to muffle it. It kind of sounds like that but I have a better description. See if you can figure this one out. The noise sounds like one of those wind chimes that people have out on their front porch (you know the ones with the different legnth bars that chime when they hit each other). It sounds like one of those except more dull and more muffled. This happens whenever I drive it, not just when I go WOT. Seems to have gotten a little worse after I switched back to 89 and did a few WOT runs with it. Anyway I used to enjoy the nice smoothness and quietness of my engine but now not so much. Anyway, this and my last post is the best that I can describe what my car is doing at this time.
    Could maybe one of these be causing the problem of the rough idle:
    Clogged fuel injector?
    Preignition from using 89 octane?
    Something else?
    What about the wierd noise? I have no clue what that noise is. All I know is it got worse after the oil change and after putting in 89 octane. Thanks bbob for any advice.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Still didn't see any reference about checking the fuel pressure regulator for leaking into the vacuum nipple.....check it.
    Just because the fuel pressure is ok does not rule out other fuel delivery problems.
    An injector could be leaking/dripping/stuck open. Loosen the fuel rail mounts and lift the rail up enough so that the injectors clear the intake manifold ports. Energize the fuel pump to build the sytem pressure and watch the injector tips for leaking.
    Jan 2004
    116
    No leaking from the fuel pressure regulator into the vacuum line. Pulled out the fuel rail out and turned the ignition to ON position to build the fuel pressure. I waited forver trying to see any signes of a leaky injector, but all are fine. Put them back in, tightened everything up and started the car. Took a mechanics stethescope and listened to each injector to see if any ones were clogged or partially clogged.... they all have a strong loud pulsating rhythm indicating they are working. So if it's not a fuel delivery problem what could it possibly be?
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    How about the EGR tubes..??? Have they been cleaned? Open the throttle blades wide open and look down the throttle bores. Those two tubes sticking up at you are supposed to be clean and not full of carbon. Rod them out with a stiff piece of wire.
    Jan 2004
    116
    EGR tubes are spotless; didn't need to be cleaned at all
    Anyway I was on empty, so I just put a full tank of 92 octane (I usually use 89 with ethanol) and after a few minutes it started to idle better and when I drive down the road that mysterious noise is much improved. Still happens most of the time but it is barely audible. Can't really notice it unless you strain to hear it.
    Anyway I've never had a bad idle and that loud of a noise when I have used 89 before. I always use 89 from the same Conoco station and have never had a problem until the last tank. I guess our search is over for the bad idle but I'll probably go back to 89 because I hate to spend $30.00 for a tank of gas.
    Still don't know what that mysterious noise is. I swear it sounds like a bearing noise but what do I know....
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    If the "marbley" noise went away with premium fuel then likely what you are hearing is spark knock or detonation.
    The 90 4.5 is tuned for premium fuel but will usually run OK on mid-grades of fuel. If it is spark knocking at part throttle on mid-grade it still hints of a problem with lack of EGR flow. If the tubes are clean then possibly the EGR solenoid is failed or the vaccum supply to the EGR solenoid is missing/plugged/disconnected. Tee in a vacuum gauge immediately at the EGR valve vacuum nipple and watch the gauge when you crowd the throttle with the trans in gear iether driving or against the brakes. The EGR valve should get a vacuum signal from the solenoid when you open the throttle. Lack of vacuun to the valve could certainly cause the engine to spark knock on lower grades of fuel at part throttle.
    I assume the engine is quite and runs OK at full throttle...??? If so, the spark knock would only be at part throttle and that would indicate an EGR problem even more.
    Jan 2004
    116
    "If the "marbley" noise went away with premium fuel then likely what you are hearing is spark knock or detonation."
    With 92 octane the marbley noise is still there at part throttle but it is barley audible and happens less often. I agree that it is probably related to the EGR system because so far it seems like it is the only culprit. I have run 89 for a long long time with no problem before so this bad idle/noise has to be due to some sort of malfunction as this. Anyway I will check out the vacuum signal thing tomorrow and see what happens.
    BTW at full throttle it purrs like a kitten. No wierd noises or poor performance or anything like that. Sounds/feels so awesome at full throttle. Gotta love an american V8.
  12. Remove Advertisements
