Self Sticky - 4.9 Engine History and Changes
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, Self Sticky - 4.9 Engine History and Changes in Cadillac Engine Discussion; 1991 -Engine introduced. Used in Fleetwood, DeVille, and Seville. 300ci with ratings of 200hp @ 4100rpm, 275lb.-ft @ 3000rpm 1992 ...
    2dfx's Avatar
    2dfx is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac DeVille
    Jun 2003
    Ontario, Canada
    31
    397
    1991
    1992
    -Platinum spark plugs now used as standard
    -TPS and throttle body changed to improve throttle feel
    -Exhaust system changed to use 2.5 inch diameter pipe
    -Exhause routing changed
    -Fleetwood's usage of the 4.9 was dropped in favor of the 5.7L 350 for the redesign of the Fleetwood
    1993
    -The new Gen2 CS144 Self cooling alternator used to provide 140 amps
    1994
    -Seville's usage of the 4.9 was dropped to favor use of the 4.6L Northstar only, leaving the DeVille as the only car left in the lineup to use the motor
    -Intake manifold redesigned for quieter operation
    -Single longitudinal exhaust routing used for a gain of 5hp and 5lb.-ft of torque
    -4T60-E received 3rd clutch, premium gear set, and rocker pin chain
    -Computer electronics now integrated into 1 unit called a PCM
    -New HD6 A/C compressor used to accomodate R134a refirdgerant
    1995
    -Exhaust system changed to reduce engine noise
    -Last year of engine production
    aguthmiller's Avatar
    aguthmiller is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS, 1998 Seville STS, 2001 Seville SLS
    Mar 2004
    Minnesota
    37
    50
    Re: Self Sticky - 4.9 Engine History and Changes
    Quote Originally Posted by 2dfx
    1991
    You forgot the Eldorado the whole way through . But if you replace "Seville" with "Seville & Eldorado", ?starting in 1992?, to my knowledge you'd be right.
    1992
    Really? When I pulled the plugs out of my '92 Eldo at 70,000 (bought it with 54k, so it would be unlikely the plugs had been replaced) they were just standard AC Delco's, not the platinums.
