smog pump adjustment
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, smog pump adjustment in Cadillac Engine Discussion; I have a loose smog pump belt on a 83 4100 and i was wondering if anyone knew where the ...
    gmman is offline Cadillac Owners Member
    Mar 2004
    3
    I have a loose smog pump belt on a 83 4100 and i was wondering if anyone knew where the adjustment is unless the belts are routed wrong as of now they are a/c to the crank to power steering and alt to water pump and smog water pump and crank any help is greatly apperciated thanks
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: smog pump adjustment
    If I remember correctly, its located at the rear of the pump. Seems like its adjusted from under the car . I remember it being akward to reach. Loosen the upper attaching bolt on the pump then look from under the car at the backside of the pump for the bracket adjuster bolt. This if from an old mans memory! sounds like you've got the belts routed correctly.
