new to forum
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, new to forum in Cadillac Engine Discussion; first off, hello to everyone thats part of the forum. from what ive been reading you guys know a great ...
    chuckdobbins's Avatar
    chuckdobbins is offline Cadillac Owners Enthusiast
    Automobile(s): 97 deville
    Mar 2004
    MA
    32
    562
    new to forum
    first off, hello to everyone thats part of the forum. from what ive been reading you guys know a great deal about these caddies.
    i bought a 90 deville off a family friend/mechanic about a year ago when i was 18 for $800. the car now has 143k miles and can still strut its stuff. ive loved this car since day 1, before i even owned it. its been in for repairs just 3 days this last year due to a security failure with the transponder thing. needless to say i had a transistor put in place to bypass the security. very affordable to say the least. i just had it painted this winter cuz my trunk was 8 different shades of gray, looks great now.
    the tranny i disliked from the start. 4 speed with rather short gear ratios. the shift to the final gear at 40mph can be a bit harsh at times. the worst is the shift into reverse, its more of a slam into reverse because the whole front end of the car rocks and makes a mean grunt. i have a small tranny fluid leak but im not sure where. before i spend the hundred bucks, would stopping the leak, and changing the fluid/gasket/filter help this fussy transmission?
    the service engine soon light has been worrying me as of late. it goes on, then goes off. then it goes on, and off. it seems to go on and off during longer idle times, like at a busy bank drive through and whatnot. is this something to worry greatly about?
    ive also been wanting to change the exhaust a little. my parents own a 99 deville with the 283 northstar and the dual exhaust looks nice, and is quiet. ive read that a camaro z28 exhaust will work, but is this a sure fit and will it be too loud? afterall, it is a "luxury sedan".
    sorry about the lengthy post, i just love my cadillac.
    TimsToy's Avatar
    TimsToy is offline Cadillac Owners Fanatic
    Jan 2004
    Mineral Point, WI.
    57
    213
    Re: new to forum
    You need to check the posts in regard to pulling the codes from your on board computer. Once you have that figured out you can post the codes you receive here, or dig a little deeper and you'll find links to the trouble codes. That will give you a much better idea of what you may need to do.
    Best of Luck,
    Tim
    Hippie's Avatar
    Hippie is offline Cadillac Owners Member
    Jul 2003
    Western IL
    61
    81
    Re: new to forum
    Quote Originally Posted by chuckdobbins
    I'd be having a pro look at that trans, that ain't right. The harsh shift on a 4T60 can be a sign of low engine vacuum or a vacuum leak, that might have something to do with your check engine light as well. Not saying that's it but worth checking into.
    As far as "short" gear ratios I'm not sure what you mean........
    Gear ratios are:
    1st : 2.92
    2nd : 1.56
    3rd : 1.00
    4th : 0.70
    It would have been nice if 1st wasn't so low and 2nd was a little lower for the Cads but that's what GM gave us. Final drive ratio in the differential is 2.73 combined with the .7 OD = 1.911 true final drive ratio.
    That's a pretty wide spread and a pretty tall final drive
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    Re: new to forum
    you can do the camaro style exhaust very simply just use the round metal tubes that connect the rear bumper to the rest of the car to make the elbows for the exhaust to stay in place. you could get a camaro's exhaust muffler like a stock one if you don't want it to loud but if you decide to go with a aftermarket muffler it will be louder then now, i have a edelbrock camaro muffler on my 90 deville and it's nice and quiet when crusing but when i open her up it turns heads. look at my pics in the deville section to see how my exhaust looks.
  7. Remove Advertisements
