Thoughts on the 4.5 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
HT4100 4.1, 4.5, 4.9 Discussion, Thoughts on the 4.5 in Cadillac Engine Discussion; Throttle Body Injection (TBI) was largely a stop-gap measure that GM used from about 1982 (correct me if I'm wrong, ...
  1. #16
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: Thoughts on the 4.5
    Throttle Body Injection (TBI) was largely a stop-gap measure that GM used from about 1982 (correct me if I'm wrong, but I think GM's 2.5L I-4 was the first GM engine to use TBI in 1982) through 1995 (when it was discontinued on the full size SUVs and pickups).
    Throttle Body Injection meters fuel into the top of the intake manifold, very similar to a carburetor. GM employed 1 and 2 injector TBI setups (all Cadillac V8s used 2 injectors--similar to a 2bbl carb).
    TBI was a cheap, but effective and reliable system that offered considerable improvement over a carburetor without much complexity. A typical TBI system only has about 5 critical engine sensors (Manifold Absolute Pressure (MAP), Coolant Temp, Oxygen, Manifold Air Temp (MAT), Throttle Position).
    Port fuel injection, by contrast, meters fuel into the intake port right above the intake valve on EACH cylinder. There are two major types of PFI: batch fire and sequential fire. In batch fire PFI, all injectors fire at once, whereas in sequential fire (what was used on the 4.5, 4.9, and 3800 among others) each injector squirts fuel immediately before the intake valve opens.
    The disadvantage to batch fire injection systems is that a driver must wait until all 8 cylinders fire to respond to a throttle input (really not that long of a time), whereas sequential injection can respond immediately to throttle changes.
  2. #17
    90Devillex32 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    30
    Thanks for the info. So my 90 deville is TBI?
  3. #18
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    30
    34,087
    No, the 1990 4.5V8 is port fuel injected, the 88-89 4.5 is TBI.
  5. #19
    leftoverture is offline Cadillac Owners Fanatic
    Apr 2004
    Lester Prairie, MN
    100
    So the 90 Eldo I'm looking at would be port injected also?
    I really want this car, wish someone would buy my snowmobile. Might help if it snowed a few inches here.
    Ugghhh!
  6. #20
    Dec 2004
    Roseville, MN.
    30
    34,087
    Yes, all of the 4.5 Cadillacs in '90 were PFI.
  7. #21
    Jun 2005
    Michigan
    668
    Actually, now that I think about it, I think the 1980 Cadillacs used TBI on the 368 engine (FI systems on the 500 and 425 ci engines were port fuel injection). That might be the first TBI system. In 1982, the HT4100, the 2.5L I-4, and the Corvette/Camaro/Firebird Chevy V-8s received TBI.
  8. #22
    Apr 2004
    Lester Prairie, MN
    100
    The great thing about TBI is it's simple and relatively cheap to fix.
  9. #23
    Apr 2004
    Lester Prairie, MN
    100
    Crap. . .looks like the Eldo I was looking at is sold. Just couldn't sell the sled fast enough.
  10. #24
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    Does the 4.5 PFI use the same transmission as the 4.9 PFI?
    Theirs is a 90 Fleetwood for sale that I may try and take a look at, If it was nice and worked out the 93 Deville with a 4.9 would probably have to go
    I was curious if it engines were about the same (besides the difference between 4.5 and 4.9). Didnt want to trade down in a sense and end up buying a more problematic car.
    IIRC the electronic trans first came out in 93 so I guess the transmissions would be different. My deville is at 97k so its still healthy, not sure the mileage on the 90 Fleet though, If it sounds ok ill try and take a look at it and check codes and whatnot.
  11. #25
    Sep 2005
    Texas
    1,005
    Just remembered this site, http://www.motorera.com/cadillac/cad...990/CAD90F.HTM
    It is indeed a different trans then I have now, Since the torque is lower should that make it considerably more reliable?
  12. #26
    MachX's Avatar
    MachX is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Sedan deVille 4.9L/1994 Lincoln Town Car 4.6L
    Dec 2004
    Chatham, Ont., Canada
    38
    258
    First, the electronic tranny came out in 91 with the 4.9 engines. And I'm not sure, but both my 4.5 and 4.9 knock rather loudly when I fire them up cold, but it goes away after a few minutes of running, I don't know if that is the 'main-bearing thump' people have described or if there is a bearing knock similar to a TON of Chrysler 4 bangers. Both engines are near identical and share many parts.
  13. #27
    99Zee28's Avatar
    99Zee28 is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Eldorado
    Mar 2004
    Orland Park IL
    35
    171
    I unfortunately have a small crack in my block right under the starter. My buddy who owns a shop found it by accident when he had to take my starter off to do something. I heard that those cracks in that place is common on the 4.5 and to not really worry about it. Not sure how true that is. Other than that the car has been great! Also, only have 116,000 miles on it.
    Dave
  14. #28
    Jenns90seville is offline Cadillac Owners Member
    Automobile(s): 1999 DeVille d'Elegance
    Amarillo, TX
    21
    I also have the cold weather piston slap. It goes away after the engine gets warm.
  15. #29
    99Zee28's Avatar
    Mar 2004
    Orland Park IL
    35
    171
    Quote Originally Posted by Jenns90seville View Post
    That is normal, always had that on mine too! Most GM engines or almost any engine for that matter has that. I just bought a new Monte Carlo with the 3.5 and surprisingly even when it was -10 out this past winter it didn't have any piston slap. I guess GM's tolerances are getting tighter.
    Later,
    Dave
  16. #30
    MachX's Avatar
    Dec 2004
    38
    258
    Well after some research, I've discovered that the hybrid mix of aluminum blocks and iron heads causes piston slap because of the fact that aluminum expands faster than iron. So I've stopped worrying about the cold slap. After 4 years of driving these cars I've gotten used to it.
  17. Remove Advertisements
