What kind of ISC motor should i get? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
HT4100 4.1, 4.5, 4.9 Discussion, What kind of ISC motor should i get? in Cadillac Engine Discussion; Hey Cad Tech I just bought a new isc motor for my Caddy and I understand the process of how ...
  1. #16
    801Hill's Avatar
    801Hill is offline Cadillac Owners Fanatic
    May 2005
    West Valley City, Utah, United
    34
    122
    Re: What kind of ISC motor should i get?
    Hey Cad Tech
    I just bought a new isc motor for my Caddy and I understand the process of how to do all these adjustments but my problem is that my diagnostics display does not work right.
    When I go into diagnostics it will run through all the codes but when I try to use hi or low buttons to go through the pcm data's it just reads 888 for all of them. It did not used to do this it used to work normally and show me the data. Do you know how to fix this problem? Is it the fuel data center need to be replace or is it pcm need to be reaplaced?
    I bought the isc cause my Caddy started to race and now when I start it it goes full throttle and I shut it off and isc will go to cliking for about 10secs and then stop. Am I right to change isc?
  2. #17
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    BTW, your stuck EGR valve has nothing to do with high idle.
  3. #18
    CadillacDonn is offline Cadillac Owners Member
    Automobile(s): '92 coupe deville
    Mar 2007
    wisconsin
    34
    9
    How do u set the idle speed? i have the same problem.
  5. #19
    Mar 2007
    wisconsin
    34
    9
    Ok I understand how to set the minumum air/idle using the diagnostics. where do i set tps does that mean 1.3 degrees on the diagnostic readout for the tps. and also how do i set the max throttle using the info from the computer i want it to be perfect.
  6. #20
    801Hill's Avatar
    May 2005
    34
    122
    ok I got it running good with my new isc and by doing tps and isc adjustments by ear and feel/trail and error. adjust start and drive, adjust start and drive....... but does anyone know how to fix a the diagnostics display to read right since mine just reads 888 for all the datas. My fuel data works fine and climate control works fine and trouble codes work fine, just my data for reading all the adjustments read 888. Its killing me because i love that feature so that i can fine tune everthing and now it doesnt work?
  7. Remove Advertisements
