Help! Caddy died and won't start
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Help! Caddy died and won't start in Cadillac Engine Discussion; I was in the middle lane, I poked the accelerator to get up to speed to get into my lane. ...
    LacSeville's Avatar
    LacSeville is offline Cadillac Owners Enthusiast
    Nov 2003
    Russellville, AR
    32
    730
    I was in the middle lane, I poked the accelerator to get up to speed to get into my lane. i got in the lane, and my car died suddenly. it didn't stumble around or choke, just died. I coasted to the gas station, and tried to crank it. First time, it didn't turn over, like it was binded, then I tried again, and it spun freely. It doesn't really sound like it has much compression or something. It's getting fuel alright. I took the rotor cap off and it looks pretty charged, but it's been doing fine. I scraped the crap off and put it back on, but it still wouldn't start. But I wouldn't think that would cause it to suddenly die anyhow. Oh geeze, I'm sooo broke what are you guys' opinon?
    LacSeville's Avatar
    Nov 2003
    Russellville, AR
    32
    730
    Re: Help! Caddy died and won't start
    no one has to reply to this. I've got plenty of ideas to try tomorrow!
    TimsToy's Avatar
    TimsToy is offline Cadillac Owners Fanatic
    Jan 2004
    Mineral Point, WI.
    57
    213
    Let us know what happened when you figure it out.
    aguthmiller's Avatar
    aguthmiller is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS, 1998 Seville STS, 2001 Seville SLS
    Mar 2004
    Minnesota
    37
    50
    [QUOTE=LacSeville] It doesn't really sound like it has much compression or something. QUOTE]
    Hmm. Take the rotor cap back off. Have someone crank the engine while you watch the rotor. If it doesn't spin, your timing chain broke or slipped off. I know that's rare, but it's possible. That would explain the loss of compression. Otherwise it sounds really strange.
    JoeBleed is offline Cadillac Owners Member
    Sep 2003
    17
    With it binding up like it did the first time i would highly guese that the timing chain broke. does it pop back into the intake any? you may want to take one valve cover off and have some one turn the engin over and see if valves move. i can't rember if the distributer runs off cam or crank. i realy don't rember.. i know when my timing chain broke my car died just like yours did.
    please post back would like to see what you come up with.
    good luck
    EDIT:: i check wtih a friend quickly.. taking the distributer cap off and watching should work. it is driven off cam and oil pump is drive off of it
    waynev is offline Cadillac Owners Member
    Mar 2004
    Dallas
    My 86 Deville did the same thing a week ago. Like was said, pull the cap off and check if the rotor is turning. Mine would turn and then not turn. The distributor gear was worn down halfway around. Sometimes it would catch and sometimes not. Replaced the distributor with one from the wrecking yard and it runs fine.
  9. Remove Advertisements
