ht 4100 question
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, ht 4100 question in Cadillac Engine Discussion; i recently changed the water pump on a 83 cadillac deville with the 4100 this is not my vehicle i ...
    gmman is offline Cadillac Owners Member
    Mar 2004
    3
    ht 4100 question
    i recently changed the water pump on a 83 cadillac deville with the 4100 this is not my vehicle i am helping a friend he did some of the work before he realized he had no clue what he was doing the problem i have is he took the belts off and i cant find a diagram anywhere also i was reading this forum and i read that a sealer should also be added is this true? well any help would be apperciated
    thanks
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: ht 4100 question
    Quote Originally Posted by gmman
    thanks
    The GM coolant supplement pellets are required for the HT4100. An acceptable substitute is the BarsLeaks "golden seal" powder in the clear tube. 6 pellets or two tubes.
    Go to the search feature in the toolbar above and search using "coolant supplement" and you should find a considerable amount of info.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Make sure the smog pump belt is properly tightened prior to the alternator belt install. If the smog belt is loose the alternator belt will slip on the water pump pulley, causing weak alt. output.
    Mar 2004
    3
    ok i got a problem i cant find any adjustment for the smog pump belt. the adjuster on the alternator (which i was told is how u tighten the smog pump belt) is not tightening the belt if anyone can help please reply
    aguthmiller's Avatar
    aguthmiller is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS, 1998 Seville STS, 2001 Seville SLS
    Mar 2004
    Minnesota
    37
    50
    Quote Originally Posted by bbob
    Absolutely! I've had 3 HT4100s, 3 - 4.9L. Of those 6, 4 lost head gaskets. Why? People before me (bought all four 100,000+ miles) didn't let them warm up before driving them (especially MN winter) and didn't put in the sealer! I have 92 Eldo with 139,000 that I've owned since it's had 54,000 on it. I put either the GM tablets or Bars leak in it every fall and have it flushed in the summer.
    I'm not saying it's the only reason, but it will help out.
    bookgee is offline Cadillac Owners Member
    Apr 2004
    phoenix,az
    48
    8
    Can anyone tell me how to time the ht4100? it takes a special machine, but i shop told me i could create an open loop, and itll tiem itself, but he ALSO said itll never need timed again. EVER, he said these engines arent like the old vacuum advanced cars and things. First, is that TRUE? and how do I actaully DO it? thanks everyone!
  9. Remove Advertisements
