| HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines. | Cadillac Forums: 88 Sedan Deville not liking the winter
12-08-06, 08:07 AM
|  | Cadillac Owners Member Cadillac(s): 88 deville | | Join Date: Nov 2005 Location: ON | | 88 Sedan Deville not liking the winter |
12-08-06, 10:51 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, 2005 Escalade 2WD | | Join Date: Jan 2003 Location: Portland, ME Age: 28 | | | Re: 88 Sedan Deville not liking the winter When was the last time the engine had a tune up? If your spark plugs, wires, cap and rotor are badly worn, the engine isn't going to want to fire right up. And that could cause the hesitation you are talking about. |
12-08-06, 11:10 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 88 Sedan Deville not liking the winter Is it carburated or injected? |
12-09-06, 02:45 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS | | Join Date: Feb 2004 Location: Nerk,Ohio Age: 29 | | | Re: 88 Sedan Deville not liking the winter ranger, 88 deville should have 4.5 tbi.
my 81 deville does the same thing, i'm not sure what causes it, but i usually don't drive it in the winter. |
12-09-06, 05:02 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 88 Sedan Deville not liking the winter Hmm, TBI. They don't require very much fuel pressure as I recall, but I'd check it and see what you have. May be a weak fuel pump. |
12-10-06, 04:20 PM
|  | Cadillac Owners Member Cadillac(s): 88 deville | | Join Date: Nov 2005 Location: ON | | | Re: 88 Sedan Deville not liking the winter It's fuel injected and as long as it's not below 0 degrees. The car runs fine. |
12-10-06, 07:36 PM
|  | Cadillac Owners Connoisseur Cadillac(s): '87 SDV | | Join Date: Jun 2005 Location: Michigan Age: 50 | | | Re: 88 Sedan Deville not liking the winter Check the Thermac system on the air cleaner snorkel. It's a vacuum operated butterfly that is closed when the engine is cold and opens via a sensor as the engine warms up. If the sensor or the vacuum motor are faulty, a warm engine will starve for fresh air, causing the bog. They usually only act up in cold weather. |
12-10-06, 09:08 PM
|  | Cadillac Owners Member Cadillac(s): 88 deville | | Join Date: Nov 2005 Location: ON | | | Re: 88 Sedan Deville not liking the winter Thanks noahsdad,
I'm gonna check that first thing in the morning.  |
12-10-06, 10:58 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 88 Sedan Deville not liking the winter Quote:
Originally Posted by noahsdad Check the Thermac system on the air cleaner snorkel. It's a vacuum operated butterfly that is closed when the engine is cold and opens via a sensor as the engine warms up. If the sensor or the vacuum motor are faulty, a warm engine will starve for fresh air, causing the bog. They usually only act up in cold weather. | Now there's something I haven't thought about in years. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
