'89 SD 4.5 Diag. code E59, nowhere to be found.
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, '89 SD 4.5 Diag. code E59, nowhere to be found. in Cadillac Engine Discussion; Hi, ive been searching through the posts and links etc.. for diagnostic codes for my 1989 Sedan Deville (4.5L) i ...
    highonchai's Avatar
    highonchai is offline Cadillac Owners Fanatic
    Automobile(s): '85 Seville Commemorative, '69 Sedan deVille, '06 CTS Sport
    Feb 2004
    Lansing, MI
    31
    424
    Question'89 SD 4.5 Diag. code E59, nowhere to be found.
    Hi, ive been searching through the posts and links etc.. for diagnostic codes for my 1989 Sedan Deville (4.5L) i check my codes and run the diag program, and ive gotten a few different codes, E30, E52 etc.. I found these with no problem, these are no big deal, just a couple glitches easily fixed, basically by resetting the codes. But the code i get the most is E59. Nowhere can i find the the Diagnostic example for the E59 code. Does anyone have the code book? ive seen them on eBay so i know theyre out there, i just cant seem to get my hands on one. Please help me out, I wish i knew what was going on. the car doesnt perform differently, only when the service engine light kicks on does it bog a little bit, barely even noticable, and i assume thats a normal thing. Does anyone know what E59 means? or have a link with that code on it for sure, dont send the links without the code, ive been there and done that. Thanks a lot guys, take it easy.
    ckucia is offline Cadillac Owners Fanatic
    Feb 2003
    127
    Re: '89 SD 4.5 Diag. code E59, nowhere to be found.
    Quote Originally Posted by highonchai
    According to this site
    http://autorepair.about.com/library/...bl-dtcs-38.htm
    (For an '88 - I don't know if '89 is the same, but it probably is)
    E059 VCC Temp Sensor Circuit
    highonchai's Avatar
    Feb 2004
    Lansing, MI
    31
    424
    Ok thanks a lot, that makes sense because when i hooked it up to a diag. machine it didnt pring up any problems, but the trani temp was in the negative degrees. Thanks for doing the research ckucia!
