1992 Eldorado Belt Size HELP! 4.9l
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, 1992 Eldorado Belt Size HELP! 4.9l in Cadillac Engine Discussion; Hiya! MY A/C compressor locked up on my 92 Eldo. i had to remove the belt and drive it home, ...
    theslider is offline Cadillac Owners Member
    Aug 2003
    23
    Hiya! MY A/C compressor locked up on my 92 Eldo. i had to remove the belt and drive it home, LUCKLY, i was only 2 blocks away! I need to know if anyone has an idea of what belt size to use to BYPASS the A/C compressor, untill i can get it fixed...
    Thanks,
    Chaz...
    bob2231's Avatar
    bob2231 is offline Cadillac Owners Enthusiast
    Sep 2003
    Tampa, Fl
    55
    520
    Re: 1992 Eldorado Belt Size HELP! 4.9l
    Quote Originally Posted by theslider
    Thanks,
    Chaz...
    You can't bypass the compressor because of the pulley location. It would be in the way of the replacement belt.
    Bob
    Caddy-chris is offline Cadillac Owners Member
    Feb 2004
    Warren Ontario Canada
    37
    52
    I am not sure of the exact size of belt that you require to bypass the air conditioning compressor, however I know that it is quite a bit shorter than the standard belt. Rest assured that it is possible to do despite what others may tell you. I have done it, and run the car like that for several months until I bothered to relplace the A/C comp.
    I you can wait until sunday afternoon, I can let you know the belt size (kept mine as a spare) when I swing by the shop.
    Chris
    bob2231's Avatar
    Sep 2003
    Tampa, Fl
    55
    520
    Quote Originally Posted by Caddy-chris
    Chris
    You're right Chris, anything is possible. Whether it's advisable or not is a seperate issue. Since there's quite a bit more involved with this than just switching belts, make sure you run down all the things he'll have to do to keep from trashing the entire system. That's why I gave him the overly simplistic answer in the first place.
    Bob
    Aug 2003
    23
    Quote Originally Posted by bob2231
    You're riht Chris, anything is possible. Whether it's advisable or not is a seperate issue. Since there's quite a bit more involved with this than just switching belts, make sure you run down all the things he'll have to do to keep from trashing the entire system. That's why I gave him the overly simplistic answer in the first place.
    Bob
    Just outta curiousity bob, How would it trash the system? does it make the motor rotate differnt? im confused..
    thanks
    chaz..
    bob2231's Avatar
    Sep 2003
    Tampa, Fl
    55
    520
    thanks
    chaz..
    These cars weren't available without A\C. That's why parts stores need to know the belt length you need. If you look at the location of the compressor, you'll see that you can't just go with a shorter belt and bypass that pulley. You need to remove the compressor. Plug all the lines, remove the fuses, make sure the wiring is out of the way etc. And most likely, you just need the clutch replaced in the comp.
    Why not just wait a few weeks while it's still fairly cold out, save up a few bucks each week, and have it fixed right ?
    Bob
    Aug 2003
    23
    Bob
    Does the compressor have to come off to install the new clutch?
    also, my pulley is locked up and i can move it up and down. its all loose.. you think its just the clutch?
    thanks
    chaz.
    bob2231's Avatar
    Sep 2003
    Tampa, Fl
    55
    520
    thanks
    chaz.
    You'll need to pull the comp. to remove the clutch, and you need a puller for that. Lots of parts stores will loan you one.
    If things were working right, and you're sure the clutch froze suddenly, that's most likely the problem. Some of the bearings tend to let go all at once. I really think I'd take it into an A\C shop and have it fixed before I got into bypassing anything. That opens a can of worms that's more involved than it seems.
    Bob
    Aug 2003
    23
    Bob
    Any Hints or helpful tip on removing the AC compressor?? Looks like you have to be plasticman to bend around and get to it..
    thanks
    chaz.
  12. Remove Advertisements
