Caddy problems
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Caddy problems in Cadillac Engine Discussion; I have a 1985 caddy fleetwood brougham with the infamous 4.1 liter v-8. Recently I begin having water leakage problems. ...
    caddyrod is offline Cadillac Owners Member
    Feb 2004
    8
    Caddy problems
    I have a 1985 caddy fleetwood brougham with the infamous 4.1 liter v-8. Recently I begin having water leakage problems. I took it to a shop whre they said it was the heater core and water pump and maybe thermostat housing. It will cost me 839 dollars to fix. I am a front end mechanic myself but I knew it is not the heater core so I had the car check out again by another mechanic with me present. There is a leak coming from above the head on the right side. It is coming from the intake. He seems to think that the head could be leaking too. Is that possible and if I change the intake gasket should I replace the head gasket too? The engine is in very good shape. caddy rod
    Blackout's Avatar
    Blackout is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FTS
    May 2003
    Dover, DE
    33
    4,577
    Feb 2004
    8
    Re: Caddy problems
    Quote Originally Posted by Blackout
    thank you sorry about posting in wrong topic. I wll let you get back to what you were doing whatever that is.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: Caddy problems
    Please dont post a new topic, I can move this into the 4.1 section! (which I am doing rihgt now)
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Caddy problems
    Try a compression test. If that checks out, you are probably fine. The intake gaskets are known for leaking, and Caddy updated thier design.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Caddy problems
    Quote Originally Posted by caddyrod
    I suspect all that you need is to replace the intake gaskets. Not a tough job to do.
    Make sure that the coolant replaced frequently and that the mandatory coolant supplement/sealer is installed.
    Always amazes me that posts like yours are quick to throw stones at the 4.1 (...1985 caddy fleetwood brougham with the infamous 4.1 liter v-8...) yet SOMEHOW that engine has managed to run fine for the last 19 YEARS. Could it really be THAT bad if it made it 19 years and is still running fine with just a coolant leak as a complaint item....????
  9. Remove Advertisements
