Originally Posted by FredMaxwell How important is the PCV? |
The importance of the
PCV system is to allow air to be drawn through the crankcase to carry impurities including corrosive chemicals out of the crankcase and into the intake (NOT GOOD since it will eventually clog up your intake and reduce power). When the engine is getting a bit old, the crankcase breather also acts to allow the fuming to get out. On a tired engine, the
PCV will be able to draw vapours and air through the crankcase at idle, but the breather will let stuff out at higher throttle openings. As the engine becomes more stuffed, the point at which
PCV can draw air in spite of the blowby will get closer and closer to idle...
