93' 4.9 Eldorado Heating
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, 93' 4.9 Eldorado Heating in Cadillac Engine Discussion; ...
    getbig is offline Cadillac Owners Member
    Automobile(s): 08 ext
    Jul 2005
    Maryland
    34
    After I did a search on the forum about flushing out the heater core. I came down to this:
    Please used the attach photo as a reference.
    As shown on the pictures, Is this the “T” that everybody is talking about ?
    If this is the “T” Am I supposed unhook everything and then clog the “number 1” and flush out “number 2” and watch the flowing water coming out of “ number 3”?
    Please correct me if I’m wrong. I need heat pretty badly. It’s been very cold, here in Maryland.
    Thanks!
    Jul 2005
    Maryland
    34
    Re: 93' 4.9 Eldorado Heating
    nobody knows about this???
    69
    82,266
    I am not positive, but I think #1 is the supply line. Unhook #2 & #3. Flush it both ways and be sure to put the restrictor back in the same leg it came out of (if it comes out).
    Jul 2005
    Maryland
    34
    Thanks for the reply Ranger.
    What do you mean the "restrictor"? is that the T?
    69
    82,266
    There is a restrictor in line 3 of the "T" I think. It is a plug with a smaller diameter hole to restrict the coolant flow. If you don't have it in there, you won't get good heat.
    donwon is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Deville
    Sep 2004
    SC.
    548
    I can see this is now 10 months old. Hopefully this will help someone.
    The "T" has an arrow pointing the way for the water flow. the restrictor is on the right side of the "T" looking at the picture in the above post.
    I am sitting here looking at a new part I got a couple of days ago from the Cadillac dealer.
    It cost $27. and change and it had to be ordered.
    The GM part number is 1648454.
    HorribleHarry is offline Cadillac Owners Member
    Automobile(s): 1971 Coupe deVille 1988 Eldorado
    Feb 2009
    Encino, Ca, SFV, LA, CA, USA,
    47
    10
    Quote Originally Posted by donwon View Post
    THERE HAS BEEN A CORRECTION TO THIS POST...
    THE RESTRICTION SHOULD GO TO THE LEFT OR PASSENGER SIDE OF THE TEE... not the right towards the thermostat!
    I know this is an old post, but I ALMOST messed up so I hope this saves someone else JIC.
    there is a post here that corrects this but I'm new so I can't post the link. grrr
    Harry
  10. Remove Advertisements
