Timing Issue
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By carnut
HT4100 4.1, 4.5, 4.9 Discussion, Timing Issue in Cadillac Engine Discussion; On an 85 seville the timing tab at the crank pulley what are the space values an where is 0 ...
    omston is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Seville
    Jan 2014
    319
    Timing Issue
    On an 85 seville the timing tab at the crank pulley what are the space values an where is 0 located i cant read mine. Please help if you know.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Timing Issue
    If you haven't unplugged the green connector by the distributor You wont see the mark. They're in 2 degree increments. You might apply some yellow chalk or white-out on the marker. Should be 10 degrees but they run better at 12.
    warnereg is offline Cadillac Owners Member
    Automobile(s): 1995 Sedan Deville
    Apr 2014
    Norton Shores, MI
    31
    12
    Re: Timing Issue
    I would keep it at 10 if you want to run stock. Those high paid engineers set the timing at 10 degrees btdc for a reason. It seems to be a controversial subject, but I will never run my timing anything other than stock spec. I have not seen any solid proof of timing changes making this motor run "better".
    Feb 2003
    california
    69
    6,689
    Re: Timing Issue
    Quote Originally Posted by warnereg View Post
    Really! Factory Timing specs are a compromise at best. Quality of gas, altitude, air density all affect optimum timing on any engine. There are no "timing police" Trust me 2 degrees above spec. will allow the engine to run better, by that I mean quicker off idle response and if closely monitored, 1 to 2 MPG improvement. BUT.... we haven't heard back from the Op so lets wait and see whats up.
    delerium75 likes this.
    Jan 2014
    319
    Re: Timing Issue
    Where exactly is this green wire? Is it connected to the distributor? Or to the multi point connector on the fire wall?
    Feb 2003
    california
    69
    6,689
    Re: Timing Issue
    Its not a green wire, its a green connector just beside the distributor. Its mentioned on the decal on your radiator support.
    Jan 2014
    319
    Re: Timing Issue
    My decal on the shrouds all washed out couldn't read it. I changed intake gaskets and removed distributor and i just don't recall seeing it but ill look for it. It starts right up and runs ok so it must not be to far off i marked distributor location before i pulled it.
    Jan 2014
    319
    Re: Timing Issue
    Are you talking about the connector out of the base of the distributor its 4 or 5 pins?
    Feb 2003
    california
    69
    6,689
    Re: Timing Issue
    Its a one wire connector. GREEN !
    Jan 2014
    319
    Re: Timing Issue
    Thanks i found it i wonder if they could have made it harder to reach? I guess if your eight feet tall its easy. My timing tabs in 4 deg increments not two.
    Jan 2014
    319
    Re: Timing Issue
    Your right its 2 deg increments i didnt see the small hash marks.
  14. Remove Advertisements
