84 4.1 Eldo
Results 1 to 10 of 10
HT4100 4.1, 4.5, 4.9 Discussion, 84 4.1 Eldo in Cadillac Engine Discussion; Hi I have a 84 Eldo 4.1 Has a hesitation under load especially when it warms up .during driving Then ...
    KenWhale is offline Cadillac Owners Member
    Aug 2005
    6
    84 4.1 Eldo
    Hi
    Has a hesitation under load especially when it warms up .during driving Then stalls out . Idle is good .
    When I step on the brake , and press the accelerator it hesitates , and usually stalls .
    I just replaced the fuel pump , and plugs . I did not replace the Wires , distributor cap [ seem ] OK .
    New Cat converter also . 200 km on the engine .
    Car sat for some time , and i am now driving...
    Ignition Module , plugged IAC ?
    Please advise what the fix could / should be
    Thanks , Ken
    vlrench is offline Cadillac Owners Member
    Jan 2005
    35
    Re: 84 4.1 Eldo
    Any error codes?
    Aug 2005
    6
    Re: 84 4.1 Eldo
    HI
    Thanks for your reply .
    No I have not checked
    Excuse my lack of knowledge , but how do I check the codes ?
    Also the Service Engine Soon light is intermittent
    Any help is appreciated , Ken
    RawjaNYC is offline Cadillac Owners Member
    Automobile(s): 84 & 88 Elegantes, 89 Allante, 91 & 93 60 Specials
    Nov 2003
    LawnGuylind, NooYawk
    45
    Re: 84 4.1 Eldo
    Here's a link to instructions and descriptions of the codes:
    http://www.ht4100.com/Diags/default.htm
    Aug 2005
    6
    Re: 84 4.1 Eldo
    Hi The codes are 12, 38 , 53 and 33
    additional info :
    I noticed smoking comming out of the crank case outlet that hooks up to the aircleaner
    Battey need replacement could that be an issue ?
    Car has recent wires , cap , rotor , fuel filter
    help !!
    Nov 2003
    45
    Re: 84 4.1 Eldo
    12= no tach signal (distributor)
    38= open MAT sensor circuit
    53= distributor signal interrupt
    33= MAP/barometer sensor correlation
    You mentioned fiddling with the distributor, I'd start there as two of your codes are centered there. If all this started after you worked on the car, you could have re-assembled someting wrong or knocked off a wire somewhere... check it out.
    If no luck, I'll look at my Factory service Manual and see what I can come up with...pressed for time at this moment....
    Aug 2005
    6
    Re: 84 4.1 Eldo
    Hi , AND THANKS
    I have 3 codes now .
    12 , 38 , and 52
    For 52 , i just replaced the battery
    on code 12 , No Distributor TACH signal ..
    Is Tach short for Tachometer ??
    Also could the ignition module be an issue , or bad coil?
    Thanks for the help !!, Ken
    Aug 2005
    6
    Re: 84 4.1 Eldo
    Quote Originally Posted by KenWhale
    Hi , AND THANKS
    12 , 38 , and 52
    New Update ::
    Now just have code 38
    Replaced the coil . and the 2 sensors in the Manifold
    Upon diangnostic i get a 12 , 38 52 , then the dredded 38 only
    What now ??
    Thks , Ken
    Nov 2003
    45
    Re: 84 4.1 Eldo
    I'd take a look at the Manifold Air Tempertature sensor (on top of engine under air filter housing) Both the MAT sensor and Cooant temperature sensors have inferior connector designs that decompose over time. Its possible that the connector has turned to mush and the wires are shorting.
    Nov 2003
    45
    Re: 84 4.1 Eldo
    If the connector looks OK I'd replace the sensor.
  13. Remove Advertisements
