Open or closed deck block
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, Open or closed deck block in Cadillac Engine Discussion; What are the 4.1-4.9's open or closed deck and is the dealer the only place to get new cylinder sleeves ...
    Formula94lt1 is offline Cadillac Owners Member
    Mar 2005
    35
    What are the 4.1-4.9's open or closed deck and is the dealer the only place to get new cylinder sleeves for them? Anyone got pics of a bare 4.9 block from the top and the bottem of the mains? Thanks...
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    Re: Open or closed deck block
    Quote Originally Posted by Formula94lt1
    The 4.x engine cylinder sleeves should be available at the local engine rebuilder supply shops. I would imagine that dealerships have them too. When purchased, a matching piston is supplied (at least it was the last time I checked).
    As for the deck configuration, the deck is wide open. The sleeves are free-standing with a rubber o-ring seal in the outer mid-section of the sleeve to ensure that no water can pass through. The o-rings are a dealer-only item when purchased seperate from the sleeves. When I last purchased a set of o-rings, the dealer was the only ones that had them ($8.00 per o-ring).
    As for re-installing the sleeves, no machine pressing is required. All that is needed is that they're a.) put back in their original places (new sleeves are to replace the old sleeve in it's origianl spot), b.) care is taken to place them back in their respective holes, so as not to tear the o-rings c.) once installed, press them firmly by hand until they're all even, then place the cylinder head gasket then head on top of the sleeves then torque the heads down. This will seal the sleeves properly and without a machinist press.
    A few things to remember when placing the sleeves back in:
    Make sure that the sleeves are in their original holes in the block and that they're in their original orientation to the block. This will help to ensure that they're aligned correctly without any sealing issues. It is a good idea to mark the sleeve-to-block orientation with a strip of non-corrosive paint or similar marking utility. DO NOT gouge an orientation mark into the block and sleeve!
    Make sure that the pistons are with their original sleeves! I cannot stress this enough. Do not mix 'n' match pistons and sleeves. Also make sure that the piston is aligned correctly to the block. This can be done by ensuring that the little notch on the top edge of the piston is facing the front of the engine.
    When a new sleeve is needed, it is likely a good idea to make sure a new piston is supplied with the sleeve. Thus far, I have only seen where the piston is always supplied with the sleeve.
    Should a new sleeve be purchased, you're going to have to make sure it is correctly aligned to the deck of the block. In all actuality, the sleeve should be a hair taller than the block deck. I'll find some specs on it later, but that's how it should be. It is best to measure the deck/sleeve height orientation before putting everything back together.
    Any questions?
    Mar 2005
    35
    Sounds like you've done it a few times No more questions at present, thanks man!
    illumina's Avatar
    Feb 2004
    The Empire...
    4,425
    Nope. Never done a single engine before...I've seen it done a million times though!
    Yeah, you could say that I've had my hands in quite a few 4.x series engines. Either on a rebuild (my '87 Seville has a new 4.5 liter transplant, running with some ass!) or some sort of major repair. And you know what? People on this forum still think I'm a retard and that I know nothing about mechanical work or even automobiles!!!
    I'll never get any respect here I think
    91TexasSeville's Avatar
    91TexasSeville is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX-V8, 1991 Eldorado
    Oct 2004
    Near Houston
    66
    1,543
    Quote Originally Posted by illumina
    I don't think that of you... I appreciate your posts!
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    57
    517
    Gee Illumina, I shore woulda liked to hear this when I started the 4.1 sleeve rehash thread....
    There may be a problem w/ finding sleeves if you're looking for a 4.1, and don't EVEN bother trying Cadillac....
    The 2 new ones my brother found for mine had numbers on them and although I don't remember it, I'll return in a day or two with the number they had on them, as well as the specs that aren't supplied in the service manual....
    I don't have any pics of the 'hollow' block, but I'll try to make a couple and put them in the rehash thread as well...
    illumina's Avatar
    Feb 2004
    The Empire...
    4,425
    Quote Originally Posted by Leeb
    When I had to look for sleeves one time, a local engine rebuilder supply shop had them. The dealership at that time had them too, just far more expensive.
  10. Remove Advertisements
