Results 1 to 3 of 3
Thread: 1990 feleetwood codes on air control panel
    Jul 2005
    30
    hi still looking for a post on the codes . not what they mean but the buttons to push to receive the codes and how to enable and disable individual injectors .
    thanks
    Sep 2005
    Re: 1990 feleetwood codes on air control panel
    Not sure if u still need this info but here goes:
    a). Off and Warmer together on the ECC.
    b). Watch for codes on the FUEL DISPLAY,
    c). at 7.0 press the HI button once E.9.5 will be displayed on FD
    d). Press the econ and warmer button together, display will show E.5.0
    e). Press HI to get to ECM override E.5.4 Cylinder balance test.
    f). Warmer cycles through INJ 01-08, cooler turns off each injector drive cct.
    Jul 2005
    30
    thank you
  • You may not post replies
