Roaring Rattling Deville
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Roaring Rattling Deville in Cadillac Engine Discussion; My 95 DeVIlle has a roaring and rattling sound as it starts to move and accelerate from idle. I dont ...
    vidot4 is offline Cadillac Owners Member
    Jul 2005
    QuestionRoaring Rattling Deville
    My 95 DeVIlle has a roaring and rattling sound as it starts to move and accelerate from idle. I dont hear it at speeds above 30 mph and when car is in Park. Pick up (i.e. acceleration) is excellent. Car has 75, 000 miles. COuld this be catalatic converter?? How much does something like this cost?
    adalla is offline Cadillac Owners Fanatic
    May 2003
    PA
    305
    Re: Roaring Rattling Deville
    Quote Originally Posted by vidot4
    If you can hear it only at acceleration and it is more pronounced while driving up a hill it might be some body parts touching exhaust lines. I had that problem for two years until bbob advised to powerbrake it on a hoist. I was beneaf the car and instantly noticed that exhaust lines moved back and touched a bracket. The problem was solved in 5 seconds by bending the bracket by hand a little bit.
    Powerbraking is putting car in D and increasing RPMs with brake applied FIRMLY.
    Because of inertia the powertrain and whole exhaust system moves back as a whole piece and can hit some body parts. I inspected everything under the car and all looked perfect. The gap between the bracket under the exhust line and the pie was some 3/4" but as soon as the car was powerbraked on the hoist everything mooved back just enough to touch the braket and resonate the whole car. As a result a terrible rattling noise....
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Also could be something like a broken motor mount causing something like the exhaust to hit when it's torqued under load, like acclerating. Do what adalla said and have a friend with you to figure out where the noise is coming from.
    OnDaSlab is offline Cadillac Owners Fanatic
    Feb 2005
    151
    im gettin a rattling noise from my 00 deville, wondering
    if you have fixed the problem.
    i know i got a engine mount broken.
    but not sure its due to this.
    crestviewpb is offline Cadillac Owners Member
    Oct 2004
    Crestview, FL
    63
    29
    Mine was the catalatic converter bad and insides rattleing around. Had a new one installed for 150.00. Sounds like new now
  8. Remove Advertisements
