At what temp should the radiator fan come on?
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, At what temp should the radiator fan come on? in Cadillac Engine Discussion; My 1992 Seville (4.9) has a 190 degree thermostat which works just fine but the radiator fan doesn't come on ...
    runforrest1 is offline Cadillac Owners Member
    Automobile(s): 1992 Seville - 4.9 engine
    Jan 2014
    southern California
    67
    8
    My 1992 Seville (4.9) has a 190 degree thermostat which works just fine but the radiator fan doesn't come on until it gets up to 223 degrees.
    Is that the usual with these guys? What controls when that comes on? My Honda has a fan temp switch that screws into the radiator and determines the temp that it kicks in.
    69
    82,383
    Re: At what temp should the radiator fan come on?
    223 sounds just about right. The fans are controlled by the PCM with an input from the ECT sensor (#516) in the intake manifold.
    http://www.gmpartsgiant.com/Page_Pro...013&SortKey=15
